Generated scale
Delfos, Jacob
jacob.delfos at MAUNSELL.COM
Tue Jan 17 20:26:24 EST 2006
As attribute of the map object, put:
UNITS dd
So you could put that below your EXTENT. I think it must default to
metres, whereas your projection is in degrees. So it thinks that each
degree is only a metre, causing the scale to go wrong.
Regards,
Jacob
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of James Net
> Sent: 18 January 2006 09:17
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Generated scale
> I'm viewing a satellite map of a large area and my mapserver
> generated scale
> seems a little wrong. Viewing a whole state (of Australia) mapserver
> generates a scale ranging from 0 ---> 0.001km (see
> attached). And when I
> zoom-in the scale bar goes to 0 ---> 0. Any ideas? I thought
> my scale should
> be like 1 ---> 1000km. Am I not reading it right? Am I
> missing or have I
> stuffed up a map file config option / setting?
> My Map file:
> MAP
> NAME WEX
> IMAGETYPE jpeg
> EXTENT 140 -41 150 -33
> SIZE 600 600
> DEBUG ON
> TRANSPARENT ON
> IMAGECOLOR 239 242 248 # The background Color.
> WEB
> LOG "mylog.log" # The Debug Log.
> TEMPLATE "template.html"
> IMAGEPATH "/var/web/tmp/"
> IMAGEURL "/tmp/"
> METADATA
> wms_title "WEX"
> wms_srs "EPSG:4283"
> wms_onlineresource
> "http://myserver/cgi-bin/mapserv?map=wex.map"
> END
> MAXSCALE 50.0
> MINSCALE 0.1
> END
> PROJECTION
> "init=epsg:4283"
> END
> SCALEBAR
> IMAGECOLOR 0 0 0
> LABEL
> COLOR 255 255 255
> SIZE TINY
> END
> STYLE 1
> SIZE 100 2
> COLOR 255 255 255
> UNITS kilometers
> INTERVALS 1
> TRANSPARENT TRUE
> STATUS ON
> END
> LAYER stuff
> END # EOF
> Thanks in advance!
> _________________________________________________________________
> Start something musical - 15 free ninemsn Music downloads!
> http://ninemsn.com.au/share/redir/adTrack.asp?mode=click&clien
> tID=667&referral=HotmailTaglineNov&URL=http://www.ninemsn.com.
> au/startsomething
