QUERYMAP and postgis
Peter Huis in 't Veld
peterh at IVS90.NL
Wed Jan 18 16:49:52 EST 2006
Bart,
Your right about the oid column, this is part of my dataset. I replaced
the geom column by the oid. The result is still the same.
Postgis 1.0.4
Postgres 8.03
MapServer 4.6
The problem I encounter are related to selecting the right coordinates
on the map. I have debugged the queries and I did forget to provide the
tablename with a schema prefix (public). So, I only have to resolve the
problem of pin pointing the right poi. Any suggestions? Can I switch on
the display of the coordinates in my browser?
Peter
Bart van den Eijnden (OSGIS) wrote:
> Peter,
> I would never suggest using the geometry column as the unique column.
> The default used is oid, but as you might know as of PostgreSQL 8.1
> this is not created anymore automatically. Older PostgreSQL versions
> do have it standard, so just leave out your USING UNIQUE in that case
> from the DATA statement. Is there not a primary key on your table
> which you can use otherwise instead of the geometry column?
> I would suggest getting some debug information out of Mapserver using
> the practices described here:
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?DebuggingMapserver
> or just log the queries which Mapserver sends at the PostgreSQL level
> (PostgreSQL logging).
> In order to solve this, tt might help also providing some version info
> (which Mapserver version, which PostgreSQL version, which PostGIS
> version etc.).
> Best regards,
> Bart
> Peter Huis in 't Veld wrote:
>> Hello
>> I've the question: How can I show the attributes of a a postgis query
>> using mapserver. At the moment I've GIS layer showing me all the
>> object in the spatial database, so the query isn't isn't the problem.
>> Changing the mode into query mode Ik get the following message:
>> msQueryByPoint(): Search returned no results. No matching record(s)
>> found.
>> I've seen the remark on the mapserver web-site by Bart vd Eijnden,
>> but this doesn't give me any additional info. I made the following
>> changes
>> to the code in order to query the Map file by clicking on the map item:
>> *QUERYMAP
>> STATUS ON
>> STYLE HILITE
>> COLOR 0 255 0
>> END
>> LAYER
>> CONNECTIONTYPE POSTGIS
>> CONNECTION ....
>> DATA "object_geom from (SELECT a, b, c, object_geom from table)
>> as myquery using unique object_geom"
>> *TOLERANCE 5*
>> CLASS
>> LABEL
>> END END
>> * TEMPLATE "query_result.html"*
>> PROJECTION
>> END
>> END
>> The query_result.html looks like:
>> <table>
>> <tr>
>> <td>[lrn]</td>
>> <td>[a]</td>
>> <td>[b]</td>
>> <td>[c]</td>
>> </tr>
>> </table>
>> Should the query_result.html be in a specific directory? I've places
>> it in htdocs where my index.html is present.
>> Thanks for any help!
>> Peter
