Terraserver WMS
Chip Taylor
work at XWB.COM
Wed Jan 18 17:05:41 EST 2006
Sorry, I renamed the layer from ortho-18 to TSOrtho1 after running the map
and before sending the message. My bad.
I think the JPEG issue is the problem. I totally missed that. As for the
projection, I know that will be a problem and will be addressed before
production. I don't think that will prevent the map from displaying.
I'll try changing the wms-format to jpeg.
Thanks for the help.
Chip
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Ed McNierney
Sent: Wednesday, January 18, 2006 1:58 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Terraserver WMS
Chip -
Are you certain that's the map file you're really using for the request
that produces that error? The error message refers to a layer named
"ortho-18", and your map file has no layer of that name.
The Microsoft TerraServer WMS services do not support GIF image requests
- the only image type supported is JPEG. Be sure to check the
GetCapabilities document carefully so you don't request things the
server can't provide.
Your EXTENT seems to indicate that you want the output map to be in some
sort of "geographic" projection, but you do not have a PROJECTION block
in your map file to specify the output projection you want. If you use
this technique you should realize that you will have problems at UTM
zone edges, as the TerraServer UTM layers will not match properly at
zone boundaries.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060118/0535709f/attachment.html
