mapscript query question
Jerry Pisk
jerry.pisk at GMAIL.COM
Thu Jan 19 12:12:37 PST 2006
Chris,
the layer is already open when you query it, the second opening might
clear out the results. Try to take that call out and move your close
call one block out.
Jerry
On 1/19/06, Christopher Condit <condit at sdsc.edu> wrote:
> I'm using C# MapScript to build my MapFile. This is working great. Now I
> want to query the MapFile programmatically – but can't seem to figure out
> how to do it. Is there a tutorial that I'm not seeing?
> Here's my code snippet:
> layerObj queryLayer = map.getLayerByName("myLayer");
> if (null != queryLayer)
> int count = queryLayer.queryByPoint(myMap, new pointObj(-82, 25, 0, 0),
> mapscript.MS_MULTIPLE, 5.0d);
> if (count > 0)
> queryLayer.open();
> for (int i = 0; i < count; i++)
> resultCacheMemberObj result = queryLayer.getResult(i);
> shapeObj shape = obisLayer.getFeature(result.shapeindex, result.tileindex);
> queryLayer.close();
> The resultCacheMemberObj never gets a value, even when query by point
> returns > 0. Here's my layer definition:
> LAYER
> CONNECTION "user/pass"
> CONNECTIONTYPE ORACLESPATIAL
> DATA "SHAPE FROM (SELECT * FROM MYTABLE WHERE NAME LIKE 'S%') USING
> UNIQUE ROWNUM"
> DUMP TRUE
> METADATA
> "wfs_title" "SimpleWFSTest"
> "gml_include_items" "all"
> END
> NAME "myLayer"
> PROJECTION
> "init=epsg:4326"
> END
> SIZEUNITS PIXELS
> STATUS DEFAULT
> TOLERANCEUNITS PIXELS
> TRANSPARENCY 100
> TYPE POINT
> UNITS DD
> CLASS
> METADATA
> END
> STYLE
> ANGLE 360
> COLOR 255 0 0
> OUTLINECOLOR 0 255 0
> SIZE 8
> SYMBOL "circle"
> END
> END
> END
> Thanks,
> Chris
More information about the MapServer-users
