Help Please on Map File
Pericles S. Nacionales
naci0002 at UMN.EDU
Fri Jan 20 12:35:22 EST 2006
Gary,
You'll need to use logical expressions to use multiple fields from your table:
LAYER #1
CLASS
EXPRESSION ('[CATEGORY]' eq 'TS' and '[ENSOPHASE]' eq 'El Nino' and
'[MAJOR]' eq 'Minor')
END
CLASS
EXPRESSION ('[CATEGORY]' eq 'H2' and '[ENSOPHASE]' eq 'El Nino' and
END
END # Layer 1
LAYER #2
CLASS
EXPRESSION ('[CATEGORY]' eq 'H4' and '[ENSOPHASE]' eq 'La Nina' and
'[MAJOR]' eq 'Major')
END
CLASS
EXPRESSION ('[CATEGORY]' eq 'H3' and '[ENSOPHASE]' eq 'La Nina' and
END
END # Layer 2
More info on expressions here:
http://mapserver.gis.umn.edu/docs/reference/mapfile/class
Cheers!
Perry
On Friday 20 January 2006 10:56, Gary Watry wrote:
> Here is what I have
> I have a database with the following
> Fields Values
> Category 'TS' 'H1' 'H2' 'H3' 'H4' 'H5'
> ENSOPhase 'El Nino' 'La Nina' 'Neutral'
> Major 'Major' 'Minor'
> I know how to filter using the
> CLASSITEM "CATERGORY"
> CLASS
> EXPRESSION /H1/
> What I need to do is filter by ENSOPhase and Major as well as by Category
> ie.layer #1
> 'TS' 'El Nino' 'Minor'
> 'H2' 'El Nino' 'Minor'
> or layer #2
> 'H4' 'La Nina' 'Major'
> 'H3' 'La Nina' 'Major'
> I build my symbology off the Category Column
Conservation Biology Program
University of Minnesota
e-mail: naci0002 at umn.edu
