mapping xy tables directly
Fischer, Brian bfischer at HOUSTONENGINEERINGINC.COM
Fri Jan 20 12:53:24 PST 2006
Hi Kevin, we are using an access database with the OGR OVF support to
display points out of a database table.  Simply create an OBDC System
DSN connection to the dateabase, create your layer in the mapfile and
.ovf file.  Then you use the layer just like you normally would with
MapServer.  I provided an example of the layer in the mapfile and ovf
file.  How this helps.  Brian
Here is the layer file:
LAYER
      NAME permits_062405
      STATUS OFF
      TYPE POINT
      CONNECTIONTYPE OGR
      CONNECTION "permits.ovf"
      DATA "permits_062405"
      HEADER permitheader.html
      TEMPLATE permitresults.html
      FOOTER permitfooter.html
      MAXSCALE 1250000
      SYMBOLSCALE 50000
      LABELMAXSCALE 100000
      LABELITEM 'PERMIT_NUM'
      CLASSITEM 'YEAR'
      CLASS
        NAME "2005 Permits"
        EXPRESSION '2005'
        SYMBOL 'star'
        COLOR 255 0 0
        SIZE 9
        MINSIZE 9
        MAXSIZE 12
      END
  END
Here is the ovf file:
<OGRVRTDataSource>
            <OGRVRTLayer name="permits_062405">
<SrcDataSource>ODBC:RLWDPERMITS,RLWD_Permits</SrcDataSource>
                        <SrcLayer>RLWD_Permits</SrcLayer>
                        <GeometryType>wkbPoint</GeometryType>
                        <GeometryField encoding="PointFromColumns"
x="X_Coordinates" y="Y_Coordinates"/>
            </OGRVRTLayer>
</OGRVRTDataSource>
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Kevin Flanders
Sent: Friday, January 20, 2006 2:33 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] mapping xy tables directly
Can anyone provide a quick description of how I can map xy tables
directly?
Kevin
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060120/ad0391a1/attachment.htm>
More information about the MapServer-users mailing list
