WMS capabilities from file?
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Mon Jan 23 05:04:45 EST 2006
Hi list,
we all know a WMS GetCapabilities response can take a long time to be
generated, which can be problematic for client applications working
real-time on the GetCapabilities interface. Therefore a lot of vendors
(ESRI, Ionic) store the WMS capabilities response on file.
I think it would be a good idea for Mapserver to support this as well. It
could be as simple as adding a new METADATA at the WEB level called
wms_capabilities_file (or maybe also include the WMS version in the name of
the metadata?). If this exists, Mapserver will return the file, if it does
not exist, it will generate dynamically.
What do others think?
Best regards,
Bart
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
