WMS ScaleHint precision
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Mon Jan 23 05:41:48 EST 2006
Please ignore this post, the value defined in the MAP file was 34999 (and
not 35000 as I thought it was) so the returned value is acceptable.
Best regards,
Bart
> -----Oorspronkelijk bericht-----
> Van: Eijnden, B. van den (Bart)
> Verzonden: maandag 23 januari 2006 11:39
> Aan: MAPSERVER-USERS (E-mail)
> Onderwerp: WMS ScaleHint precision
> Hi list,
> we are having some issues with the precision of the ScaleHint values. For
> instance, we have defined a scale of 35000 in the MAP file, but when
> calculating scalehints back to meters (this is done in a utility which
> comes with Chameleon called wmsparse), we get:
> 34998,99841
> Is there a way to fix this so the "reverse-engineered" values become more
> precise?
> Best regards,
> Bart
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
