mixed geometry layers
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Mon Jan 23 05:58:33 EST 2006
Hi list,
are there any plans for Mapserver to support mixed geometry layers (eg
points, lines and polygons), assuming the attributes are the same so they
belong to the same featuretype?
We have a lot of datasets in which there are points, lines and polygons, and
now they all have to be treated as separate layers which is very confusing
for users.
Best regards,
Bart
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
