JPEG2000
Frank Warmerdam
warmerdam at POBOX.COM
Mon Jan 23 07:17:31 EST 2006
On 1/23/06, Stéphane RIFF <stephane.riff at cerene.fr> wrote:
> Hi,
> Does mapserver can send JPEG2000 file to client ???
Stefane,
Yes, this is possible with a suitably defined outputformat
declaration in your mapfile. It is also necessary that MapServer
be built with GDAL support, and that GDAL be built with one
of the JPEG2000 drivers that supports output. I haven't actually
tested it, but I imagine a declaration like this would do the trick
if you had built in the ECW SDK (as in FWTools for instance):
OUTPUTFORMAT
NAME jpeg2000
DRIVER "JPWECW"
MIMETYPE "image/jpeg2000"
IMAGEMODE RGB
END
I would add that most browsers do not directly support jpeg2000
yet, so having a WMS produce jpeg2000 is of limited value.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
