Resolution of SWF
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Mon Jan 23 08:53:56 PST 2006
Hi There,
  I am not sure I undestand fully the request but I will try any way. If
you want to get a full resolutionfor the swf output, there is a setting
that needs to be set up called FORMATOPTION "FULL_RESOLUTION=FALSE" that
you need to put inside your output format. That ensures that all the
points (nodes) of your data are transferred into the flash movie without
any filtering applied due to resolution or scale.   Please check this
document for more details
(http://www2.dmsolutions.ca/mapserver/dl/FlashMapserverUserDoc.html).
 If it does not adress your question please give more details.
 Later,
Salvador Vidal wrote:
>Well,
> I want to send to flash the cartograpy of all a town (in a time), and in
> flash, zoom out, in and pan, without connection to the server.
> (The first time is a lot of information, but no more)
> Ok, but I have a doubt.
> The "resolution" that i give to the movie clip.
> A) I SEND
>    MAP SIZE 500, 500
>    MAP EXTEND 600000 700000 602000 702000
> B) A MAP MORE BIG WHIT the same coordinates (I better resolution in SWF)
>    MAP SIZE 2000, 2000
>    and scale in flash?
>    I think that no, , and the resolution is the same,
>    but i need a response qualified.
> Understand me?
> Many thanks.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
More information about the MapServer-users mailing list
