Reprojection problem
Ed McNierney
ed at TOPOZONE.COM
Mon Jan 23 12:42:50 EST 2006
JF -
That sounds very strange! Can you post the LAYER definition for the troublesome layer, or at least the PROJECTION block for it?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Doyon, Jean-Francois
Sent: Monday, January 23, 2006 12:03 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Reprojection problem
Hello,
I recently upgraded from 3.6.6 to 4.6.1, and now I'm having problems with a map that reprojects a single layer ...
I have a MAP level PROJECTION object, and one layer with a different PROJECTION than the others ... (The map is in an LCC projection, and the layer in geographic).
This used to work fine in 3.6.6, but now I get "msDrawMap(): Image handling error. Failed to draw layer named 'featureannotate'." ... That layer being the one in geographic that should be getting reprojected.
If I take out the PROJECTION parameter of the layer, no errors! I tried moving it's definition with the layer, which didn't change anything ... I also tried using both epsg codes and in-line definitions, which also didn't help :(
I was using PROJ 4.4.5 ... Upgraded to 4.4.9 ... That didn't help. I re-compiled MS just to be safe, the problem remains ...
I have a WMS server running off the same setup without complaints (including reprojection). The shapefile looks ok, shpdump/shptest and dbfdump didn't produce anything out of the ordinary ...
Any ideas?
Thanks!
Jean-François Doyon
Internet Service Development and Systems Support / Spécialiste de dèveloppements internet et soutien technique Canada Centre for Remote Sensing/Centre Canadien de télédétection Natural Resources Canada/Ressources Naturelles Canada http://atlas.gc.ca
Tel./Tél.: (613) 992-4902
Fax: (613) 947-2410
