Reprojection problem
Doyon, Jean-Francois
Jean-Francois.Doyon at CCRS.NRCAN.GC.CA
Mon Jan 23 13:28:29 EST 2006
Aha!
It looks like the combination of cgi map_layer_class_expression and the
projection causes MS to generate an error!
This is a bug :(
J.F.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Doyon, Jean-Francois
Sent: January 23, 2006 1:17 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Reprojection problem
Here you go Ed ... I'm at a loss! Right now I have to think there's a
bizarre issue with the data, or maybe it's the fact I set the expression and
symbol via the URL? I 'll look into that last one ...
The MAP PROJECTION:
PROJECTION
"init=epsg:42304"
END
The LAYER:
LAYER
NAME featureannotate
TYPE point
STATUS off
DATA geo_np
PROJECTION
"init=epsg:4326"
END
METADATA
LEGEND_GROUP "theme"
GROUP_CONTROLLER "0"
LAY_TITLE "Annotation layer for feature"
CHECKABLE "0"
LEGEND_ORDER "-1"
END
LABELITEM "FEATURE_NA"
CLASSITEM "UNIQUE_KEY"
CLASS
EXPRESSION "w8g9q7regc87ctr8743tbca084ytc"
SYMBOL -1
SIZE 30
COLOR 0 0 0
LABEL
TYPE TRUETYPE
FONT "arial"
SIZE 14
COLOR 0 0 0
OUTLINECOLOR 226 226 226
POSITION ur
FORCE TRUE
END
END
END
J.F.
Sent: January 23, 2006 12:43 PM
To: Doyon, Jean-Francois; MAPSERVER-USERS at LISTS.UMN.EDU
Subject: RE: [UMN_MAPSERVER-USERS] Reprojection problem
JF -
That sounds very strange! Can you post the LAYER definition for the
troublesome layer, or at least the PROJECTION block for it?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
Sent: Monday, January 23, 2006 12:03 PM
Subject: [UMN_MAPSERVER-USERS] Reprojection problem
Hello,
I recently upgraded from 3.6.6 to 4.6.1, and now I'm having problems with a
map that reprojects a single layer ...
I have a MAP level PROJECTION object, and one layer with a different
PROJECTION than the others ... (The map is in an LCC projection, and the
layer in geographic).
This used to work fine in 3.6.6, but now I get "msDrawMap(): Image handling
error. Failed to draw layer named 'featureannotate'." ... That layer being
the one in geographic that should be getting reprojected.
If I take out the PROJECTION parameter of the layer, no errors! I tried
moving it's definition with the layer, which didn't change anything ... I
also tried using both epsg codes and in-line definitions, which also didn't
help :(
I was using PROJ 4.4.5 ... Upgraded to 4.4.9 ... That didn't help. I
re-compiled MS just to be safe, the problem remains ...
I have a WMS server running off the same setup without complaints (including
reprojection). The shapefile looks ok, shpdump/shptest and dbfdump didn't
produce anything out of the ordinary ...
Any ideas?
Thanks!
Jean-François Doyon
Internet Service Development and Systems Support / Spécialiste de
dèveloppements internet et soutien technique Canada Centre for Remote
Sensing/Centre Canadien de télédétection Natural Resources Canada/Ressources
Naturelles Canada http://atlas.gc.ca
Tel./Tél.: (613) 992-4902
Fax: (613) 947-2410
