Projection problems
Dave K
dev at RUFFNESS.COM
Tue Jan 24 08:28:14 EST 2006
Hi there,
I am having some problems reprojecting a map. The map comes from a WMS
server and is in espg:4236 which as I understand it means that it uses the
WGS84 datum and ellipsoid, but has no inherent projection. I then want to
project the map using a Transverse Mercator projection (which I'm told has
the least distortion).
If I access the map without the PROJECTION clause (or with it set to
epsg:4326) the map displays fine and for some reason looks like it is in the
standard Mercator projection.
However, as soon as I include the PROJECTION clause the map becomes
completely blank.
My extents are:
MINX=-180
MINY=90
MAXX=180
MAXY=-90
... which should be displaying the entire world.
Am I missing something fundamental here?
Cheers,
Dave K
MAP
OUTPUTFORMAT
NAME swf
MIMETYPE "application/x-shockwave-flash"
DRIVER "SWF"
IMAGEMODE PC256
FORMATOPTION "OUTPUTMODE=SINGLE"
END
# This bit is causing a problem
PROJECTION
"proj=tmerc"
"ellps=WGS84"
"datum=WGS84"
"lat_0=0"
"lon_0=0"
"k=0.9996"
"x_0=0"
END
LAYER
NAME "demis"
STATUS OFF
TYPE RASTER
CONNECTIONTYPE WMS
CONNECTION
"http://www2.demis.nl/WMS/wms.asp?REQUEST=GetMap&LAYERS=*&FORMAT=png&TRANSPARENT=true&EXCEPTIONS=INIMAGE&WMS=WorldMap"
METADATA
"wms_title" "Demis"
"wms_name" "*"
"wms_server_version" "1.1.1"
"wms_srs" "epsg:4326"
"wms_format" "image/png"
END
PROJECTION
"init=epsg:4326"
# This is the same as:
#"proj=latlong" (No projection)
#"ellps=WGS84"
#"datum=WGS84"
END
END
