e00 to something OGR can read
Jerl Simpson jerl.simpso at GMAIL.COM
Tue Jan 24 07:59:12 PST 2006
I used the avcimport to convert the E00 files to the arc/info binary.  But I
lose data in the process.  Same thing as with the e002shp.
For instance, I have a file called PPPOINT.E00.  This file contains
Populated Places for Honduras in Point format.  City points basically.  This
file contains the lat/lons of the points, and city names.
when I use avcimport the city names are lost, and all I have are the points,
no names.
Is there a way to keep the city names?  I might need to use the library to
create my own program, but then I still don't know how they city names join
to the lat/lon information.
Thanks again,
Jerl
On 1/24/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> On 1/24/06, Jerl Simpson <jerl.simpso at gmail.com> wrote:
> > Hello,
> > I'm looking for a program that will convert e00 files to something OGR
> can
> > read.  Preferrably ESRI Shape files, but I really don't care.
> > I found e002shp but it doesn't seem to retain all the information I
> need.
> > There might be multiple versions of e002shp or even different authors.
> > It would be best if I could do this command line in a *nix environment.
> > If anyone has any suggestions I'd love to know.  I've tried to do this
> > before but with little luck.
> Jerl,
> I would suggest you use the "avcimport" program to convert the
> E00 file to an arc/info binary vector coverage which OGR can
> read.
>   http://avce00.maptools.org/
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060124/fa005aac/attachment.htm>
More information about the MapServer-users mailing list
