Projection with Mapserver & PRJ
Matthew Perry
perrygeo at GMAIL.COM
Tue Jan 24 16:10:21 EST 2006
Brian,
Mapserver, as far as I know, doesn't recognize .prj files. You have to
define a PROJECTION for every layer which is not in the same
projeciton as the map.
To translate your .prj file into the appropriate proj string, I've
found http://www.remotesensing.org/geotiff/proj_list/ to be a good
resource.
If the projection is fairly common, it also likely that it is the EPSG
database which can be searched online at http://ocean.csl.co.uk/ .. in
this case use the "init=epsg:xxxx" syntax instead of the full proj
definition.
hope this helps a bit,
Matt Perry
On 1/24/06, Brian Peschel <brianp at occinc.com> wrote:
> Does MapServer use PRJ files? I need to do some projections with shape
> files. All of my shape files sets have prj file (ie town.shp, town.shx,
> town.dbf, town.prj). If I setup a map level projection like:
> PROJECTION
> "init=epsg:4326"
> END
> do I need to setup a layer level projection also? Or will MapServer read
> the PRJ files and do the conversion on the fly for me? I am struggling to
> understand how to convert a PRJ file into the PROJ.4 parameters like:
> PROJECTION
> "proj=laea"
> "ellps=clrk66"
> "lat_0=45"
> "lon_0=-100"
> END
> (which is from the tutorial, and is not the settings I need).
> Any help in this would be appreciated...
> Brian
Matt Perry
perrygeo at gmail.com
http://www.perrygeo.net
