Question about hiding map= parameter
Steve Lime
steve.lime at DNR.STATE.MN.US
Tue Jan 24 23:34:17 EST 2006
The easiest way to do this is to hide individual mapfiles behind environment variables. You still need the map parameter but you point to a env variable rather than a "file". So, if in Apache's config file you do:
setenv TESTY /ms4w/apps/Liang/hotdocs/test1.map
then you can do:
http://.../cgi-bin/mapserv.exe?map=TESTY&...
If you want to obscure things even further you might want to use a small wrapper script that itself invokes MapServer with a particular mapfile.
Steve
>>> <lltous at MSN.COM> 01/24/06 9:49 PM >>>
I'm trying to hide the map= parameter, but the server always says "The
requested URL /cgi-bin/Liang was not found on this server". I have copied
mapserv.exe to Liang.exe and added the sentence---- SetEnvIf Request_URI
"/cgi-bin/Liang" MS_MAPFILE="/ms4w/apps/Liang/hotdocs/test1.map"---- to
httpd.conf.
Any one can give me some advice? Thank you in advance.
_________________________________________________________________
MSN Messenger: http://messenger.msn.com/cn
