Mapserver and ArcSDE: issues on compiling and connecting to
Francesco Sozzi
fsozzi at INTERCAD.CH
Wed Jan 25 10:18:57 EST 2006
Hi Andreas,
Many thanks for your detailed suggestions.
I will try them as soon as my ArcSde customers will be ready for test.
Best regards
Francesco
----- Original Message -----
From: "Andreas Albarello" <andreas.albarello at TERRITORIUMONLINE.COM>
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Wednesday, January 25, 2006 3:02 PM
Subject: Re: [UMN_MAPSERVER-USERS] Mapserver and ArcSDE: issues on compiling
and connecting to
> Francesco,
>> 1) to compile Mapserver enabling ArcSDE do I need an ArcSDE licence or is
>> it enough to have it installed (and of course not running)?
> to just *compile* MapServer with ArcSDE support all you need are three or
> four import library files (.a or .lib, depending on your operating
> system). Those files tell MapServer that all the specific functions
> required to connect to an ArcSDE database are located in some dynamic link
> library/shared object (.dll or .so) files. These dynamic link/shared
> object files are then required when you execute MapServer.
> So, in order to compile as well as to execute a copy of MapServer with
> ArcSDE support you don't even need to have ArcSDE installed on that
> particular machine.
>> 2) is it possible to download from somewhere ArcSDE files required for
>> compiling for free?
> As far as I know, those files are *not* available for free. They ship with
> each copy of ArcSDE and are included one of those seven or eight disks
> which is labeled "Client" or "C API". AFAIK, they don't get installed with
> the common ArcSDE setup procedure.
>> 3) to make Mapserver connect to a remote ArcSDE server, do I need install
>> some sort of client on the Mapserver machine?
> You don't need a particular client to connect to an ArcSDE server
> (independently on whether it is local or remote), you just need to ensure
> that on every machine running your copy of MapServer a copy of those
> dll/so files is available as well. They themselves act as client.
>> 4) is it possibnle to get this sort of client for free or do I neeed to
>> buy a licence?
> Same as above: import libraries as well as dynamic link libraries ship
> with each copy of ArcSDE. Therefore you just need a regular ArcSDE
> package.
>> Thanks for help and best regards
>> Francesco Sozzi
> Best regards,
> Andreas Albarello
> Analysis & SW Development
> Territorium Online srl/GmbH
> Via Buozzi Str. 12 - I 39100 Bolzano/Bozen
> email: andreas.albarello at territoriumonline.com
> web: www.territoriumonline.com
