Change image resolution in mapfile
Aaron Koning aaronkoning at GMAIL.COM
Wed Jan 25 16:17:18 PST 2006
Are you using PHP MapScript? PHP has a max execution time limit variable
(default is 30 seconds) in the php.ini file that causes this problem when
using PHP MapScript.
Aaron
On 1/25/06, krishna S <kris_rock82 at yahoo.com> wrote:
> Thanks for all your replies guys ........
> I was trying to create a 24" X 24" map with a 300 dpi thats 7200X7200
> pixels map. I set the size to this pixels, when i run the mapserver it
> gives me an error saying "Fatal error: Maximum execution time of 30
> seconds
> exceeded " but it generated the map with the resolution that i gave and
> the
> map is pretty good looking except it has some aliasing effect which i am
> working on now, the image format i used is JPEG. I guess this what i have
> to do ....
> ultimately i need to convert this wall map into pdf form for the
> clients ....
> Thanks again for all your time guys ...
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060125/fe4a44ac/attachment.htm>
More information about the MapServer-users mailing list
