MapServer Installation issues
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Thu Jan 26 11:08:02 EST 2006
Which one? If you are talking about MS4W then yes it is supposed to
contain everything you need to get MapServer running. (there is also an
MS4W mailing list for exactly this issue)
jeff
Ben Crane wrote:
> I've downloaded that one. Does it contain the GD and regex lib? What about
> individual image dlls for png, etc? I have tried running the tutorial
> through the installed MapServer but I get a mapLoad() error stating that
> the "map" mode isn't activated (wrong word I know)- I went back to the
> Mapserver website to find out how to sort it out. It can find the *.map
> file (I have ensured it is in the correct place) so it's not the standard
> error stating the map file couldn't be found.
> But if this windows installer has everything to make mapserver work and I
> don't require anything else then I'll head back to the drawing board and
> have another go, must be a mistake I've made somewhere along the line
> Ben
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
