MapServer Installation issues {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Fri Jan 27 07:31:18 EST 2006
Hi Ben,
You should set a hidden form variable MAP and assign the path to your map
file to it.
e.g.
<input type="hidden" name="map" value="path/to/your/map/file">
Zoltan
On Fri, 27 Jan 2006, Ben Crane wrote:
> David,
> Sorry for the delay, here is the error message I get when trying to run my
> map file via mapserv.exe
> loadMap(): Web application error. CGI variable "map" is not set.
> Regards
> Ben
