Win32 Compilation
Frank Warmerdam
warmerdam at POBOX.COM
Fri Jan 27 07:33:34 PST 2006
On 1/27/06, Ted Quinby <quinby at earthit.com> wrote:
> When I execute Mapserver –v at the command prompt, I get the following error:
> "The ordinal 134 could not be located in the dynamic link library bgd.dll"
Ted,
I would suggest you inspect your system to see if you have more
than one bgd.dll on it. I suspect an older bgd.dll in \windows\system32
is getting used instead of the one in C:\projects\gd\gdwin32.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the MapServer-users
