What is a wrapper script?
Steven Monai
stevem at SPATIALMAPPING.COM
Fri Jan 27 11:23:41 EST 2006
Since you're running MS4W, you could try a wrapper script that I wrote in
PHP. It works well for me on Windows 2000 & MS4W. Unfortunately, I think
it's too large (currently 740 lines) to quote here. If you are interested, I
can email it to you off-list.
Regards,
-SM
-----Original Message-----
Sent: Thursday, January 26, 2006 7:26 PM
To: stevem at SPATIALMAPPING.COM
Subject: Re: What is a wrapper script?
Thank you for your reply.
I'm using Windows XP. Thus I can not use the shell script. Do you have an
idea which scripting language I should use. Some people tell me that I need
to use perl, but the MS4W does not have perl support. Is that right? Thanks
again.
Liang
>From: Steven Monai <stevem at SPATIALMAPPING.COM>
>To: MAPSERVER-USERS at LISTS.UMN.EDU, Liang Zou <lltous at MSN.COM>
>Date: Thu, 26 Jan 2006 11:02:40 -0600
>Liang:
>I haved used the following shell script on a Linux box (although it
>should be generic enough to run on any OS with /bin/sh):
>#!/bin/sh
>MAPSERV="/path/to/my/mapserv"
>MAPFILE="/path/to/my/mapfile.map"
>if [ "${REQUEST_METHOD}" = "GET" ]; then
> if [ -z "${QUERY_STRING}" ]; then
> QUERY_STRING="map=${MAPFILE}"
> else
> QUERY_STRING="map=${MAPFILE}&${QUERY_STRING}"
> fi
> exec ${MAPSERV}
>else
> echo "Sorry, I only understand GET requests."
>fi
>exit 1
># End of Script
>You should set the MAPSERV and MAPFILE variables as appropriate for
>your configuration. Then put the script in your web server's cgi-bin
>directory, and make it executable.
>I haven't ever needed POST capability, so I can't tell you offhand how
>to modify the script to handle POST requests. Maybe someone else can
>chime in with the solution.
>Hope this helps,
>-SM
>On Thu, 26 Jan 2006 02:13:36 +0800, =?gb2312?B?194gwcE=?=
><lltous at MSN.COM>
>wrote:
> >hi everyone,
> >I don't know how to create a simple wrapper script to hide the map=
> >parameter. Would you please give me some clues about the wrapper script?
> >How can I create one? Is there a tool to create it?
> >Thank you very much.
> >Liang
> >_________________________________________________________________
> >Ãâ·ÑÏÂÔØ MSN Explorer: http://explorer.msn.com/lccn
Express yourself instantly with MSN Messenger! Download today it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
