Improve performance in Mapserver on Postgis-Layer using
FILTER (workaround for the TOAST-Problem)
Paul Ramsey
pramsey at REFRACTIONS.NET
Fri Jan 27 12:07:46 EST 2006
Leonhard,
You might be able to make some headway with the evil "!BOX!" hack.
In your data statement, if you compose it thusly:
DATA "the_geom from (select gid,the_geom from thetable where the_geom
&& !BOX!) using unique gid"
When the postgis driver encounters the evil !BOX! it will replace it
with the current mapserver bounding box. I think it also eschews
building an extra WHERE clause with it, although I am not certain of
that. Anyways, you could use !BOX! to put in an extra && clause on
your untoasted column.
P
On Jan 27, 2006, at 4:38 AM, Leonhard Dietze wrote:
> Hi,
> I have several layers with rather large (detailed)
> Polygon-geometries in PostGIS. While searching for
> possible solutions to improve the performance of
> my mapping-application I read about the TOAST-
> Problem. (I am using MapServer version 4.6.1 and
> Postgres 8.0.1)
> After further research I read about a possible
> Workaround for TOAST in PostGIS: I created a new
> column in my Postgres-Table where only the
> BoundingBox (bbox) is stored and use this as a
> filter-attribute while selecting the geometry
> (See:
> http://postgis.refractions.net/docs/ch05.html#id2789728
> If I do this manually, then the query only takes
> 40% of the time needed before.
> Unfortunately I do not know if (or how) it is
> possible to tell the mapserver to use this "bbox"
> for the filter. If I use the parameter
> 'FILTER "bbox"'
> in the map-file then this is inserted at the wrong
> position in the SQL-Query String. The full
> SQL-String can be found below together with the
> explanation of the parameters.
> The normal FILTER within the SQL-String looks as
> follows:
> "SELECT ... WHERE staat_geom_test && setSRID('BOX3D(137493
> 4817476,616506
> 5222523)'::BOX3D, 4326 );"
> And with the FILTER-param from the map-file:
> SELECT ... WHERE (bbox) and (staat_geom_test && setSRID('BOX3D(137493
> 4817476,616506 5222523)'::BOX3D,4326) );
> But it should look like this:
> SELECT ... WHERE bbox && setSRID('BOX3D(137493 4817476,616506
> 5222523)'::
> BOX3D, 4326 );
> Can somebody tell me if this is possible or
> do I have to dig into the source code?
> Thanks in advance.
> Leo
> FULL SQL-Query String:
> - "staat_geom_test" is the column with
> the full geometry
> - "bbox" is the column with the BoundingBox
> SELECT
> h::text,asbinary(force_collection(force_2d
> (staat_geom_test)),'XDR'),gid::
> text
> from u_g1_1820 as foo WHERE bbox &&
> setSRID('BOX3D(137493.827160494
> 4817476.39796659,616506.172839506
> 5222523.60203341)'::BOX3D, 4326 );
> Excerpt from the map-file
> LAYER
> CONNECTIONTYPE postgis
> NAME laender_33n_1820
> CONNECTION "user=xxxx
> password=xxxx dbname=hgis_germany host=xxx"
> DATA "staat_geom_test from
> u_g1_1820 as foo using unique gid using srid=4326"
> STATUS OFF
> TYPE POLYGON
> TRANSPARENCY 95
> DUMP true
> CLASSITEM h
> CLASS
> EXPRESSION /2/
> NAME "Länder innen 1820"
> COLOR 255 235 190
> OUTLINECOLOR 150 150 150
> SIZE 8
> TEMPLATE "templates/tpl_combined.html"
> END
> CLASS
> EXPRESSION /5/
> NAME "Länder 1820 besond."
> COLOR 204 204 204
> OUTLINECOLOR 235 235 235
> SIZE 8
> END
> CLASS
> NAME "Länder aussen 1820"
> COLOR 235 235 235
> SIZE 8
> END
> METADATA
> "title" "Länder 1820"
> "wms_name" "laender_33n_1820"
> "wms_title" "Länder 1820"
> "wms_srs" "EPSG:4326"
> "wms_server_version" "1.1.0"
> "wms_format" "image/png"
> END
> END
> Institut i3mainz
> Fachhochschule Mainz
> Leonhard Dietze
> Holzstraße 36
> 55116 Mainz
> Tel.: 06131-2859-686
> dietze at geoinform.fh-mainz.de
