problem in compiling 4.8-rc3
John Cartwright
John.C.Cartwright at NOAA.GOV
Sun Jan 29 02:23:47 EST 2006
Hello All,
I'm having a problem compiling 4.8 that seems to be related to the
gdFontCacheSetup check:
configure: checking where libiconv is installed...
checking for iconv_open in -lc... no
checking for libiconv_open in -liconv... no
checking for libiconv_open in -liconv... yes
using libiconv from system libs.
libiconv found. Enabling internationalization (-DUSE_ICONV)
configure: checking for GD 2.0.16 or higher...
checking for gdFontCacheSetup in -lgd... no
configure: checking whether GD needs libiconv...
configure: error: Could not find gd.h or libgd.la/libgd.so in
/usr/local/graphicslibs/lib. Make sure GD 2.0.16 or higher is compiled
before calling configure. You may also get this error if you didn't
specify the appropriate location for one of GD's dependencies (freetype,
libpng, libjpeg or libiconv).
I'm using the same gd-2.0.33 and configuration line that compiled
successfully for 4.6.0.
I've been able to replicate the problem on both a RedHat ES3 amd Mac OS
10.4 system.
Thanks for any help!
-- john
