scale?
Luis Treviño Huerta
ltrevino at GPOBSI.COM.MX
Mon Jan 30 11:20:45 EST 2006
Jeremy:
you can use [scale] in your template file.
Use some javascript to format the value of scale (like: 1:50,000 or 1:50.000). I have a small code that does this formating using a getElementById. if you want it I can mail it to you.
Regards
Luis
----- Original Message -----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Monday, January 30, 2006 9:45 AM
Subject: [UMN_MAPSERVER-USERS] scale?
Hi All,
This should be an easy question, however I cant find information on it....
How does one display the scale of a map? Im looking to have mapserver (or other means?) produce a scale like "1:50 000", rather than the scale bar.
Thanks
Jeremy
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On Behalf Of Jerl Simpson
Sent: January 30, 2006 10:27 AM
Subject: [UMN_MAPSERVER-USERS] setting variable value in mapfile
Hello,
I know I can easily use variables in a mapfile, when the value comes from cookies or a GET request. But what about setting a variable inside the mapfile itself?
Something like:
HIGHWAY_MAX_SCALE=2000000
HIGHWAY_MIN_SCALE=90000
or
HIGHWAY_COLOR="255 250 115"
then be able to use something like:
COLOR %HIGHWAY_COLOR%
in a CLASS
That way if I decide I want to change a color, I can change it once, and have it take affect for everywhere else?
Thanks,
Jerl
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060130/327b95d2/attachment.html
