scale?
Luis Treviño Huerta
ltrevino at GPOBSI.COM.MX
Mon Jan 30 08:50:31 PST 2006
Jeremy:
The substitution of the [scale] value is done by mapserver CGI.
this is the javascript function:
function TomaEscala(scale){
var escala, escalaStr, decimal;
escala = scale;
escala *= 100;
escala = Math.round(escala);
escala /= 100;
escalaStr = Math.abs(escala).toString();
entero = escalaStr.substr (0,escalaStr.length-3);
if (entero.length > 3) {
longitud = entero.length % 3;
while (longitud < entero.length) {
if (longitud == 0) {
longitud = 3;
entero = entero.substr (0,longitud) + "," + entero.substr(longitud,entero.length);
longitud += 4;
escalaStr = entero;
if (document.createTextNode){
var mytext=document.createTextNode(escalaStr)
document.getElementById("MyElementID").appendChild(mytext)
You can call this fuction on the <body onload="TomaEscala([scale]);"> of your template.
(some words are in spanish but I'm sure is not a problem)
Regards,
Luis
----- Original Message -----
To: 'Luis Treviño Huerta' ; MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Monday, January 30, 2006 10:38 AM
Subject: RE: [UMN_MAPSERVER-USERS] scale?
Thanks for the reply Luis,
I would indeed like to see your code.
>>you can use [scale] in your template file.
Formating aside, Im assuming that the template file need to have some extra code inorder to subsitute [scale] with the value of the scale. Is this assumption correct? If so, where can I find that code?
Thanks
Jeremy
-----Original Message-----
From: Luis Treviño Huerta [mailto:ltrevino at gpobsi.com.mx]
Sent: January 30, 2006 11:21 AM
To: Sears, Jeremy; MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] scale?
Jeremy:
Use some javascript to format the value of scale (like: 1:50,000 or 1:50.000). I have a small code that does this formating using a getElementById. if you want it I can mail it to you.
Regards
Luis
To: MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Monday, January 30, 2006 9:45 AM
Subject: [UMN_MAPSERVER-USERS] scale?
Hi All,
This should be an easy question, however I cant find information on it....
How does one display the scale of a map? Im looking to have mapserver (or other means?) produce a scale like "1:50 000", rather than the scale bar.
Thanks
Jeremy
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On Behalf Of Jerl Simpson
Sent: January 30, 2006 10:27 AM
Subject: [UMN_MAPSERVER-USERS] setting variable value in mapfile
Hello,
I know I can easily use variables in a mapfile, when the value comes from cookies or a GET request. But what about setting a variable inside the mapfile itself?
Something like:
HIGHWAY_MAX_SCALE=2000000
HIGHWAY_MIN_SCALE=90000
or
HIGHWAY_COLOR="255 250 115"
then be able to use something like:
COLOR %HIGHWAY_COLOR%
in a CLASS
That way if I decide I want to change a color, I can change it once, and have it take affect for everywhere else?
Thanks,
Jerl
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060130/9505dbb7/attachment.htm>
More information about the MapServer-users
