Raster Images
Frank Warmerdam
warmerdam at POBOX.COM
Mon Jan 30 22:15:26 EST 2006
On 1/30/06, Bryce Bangerter <bryceb at tulgagames.com> wrote:
> LAYER
> NAME "Terrain"
> TYPE RASTER
> STATUS ON
> DATA "../graphics/testing_29_28.png"
> DEBUG ON
> END
> END # MAPFILE
> Debug doesn't output any errors.
> testing_29_28.png is a 24 bit image that is 125x125 pixels.
> All I get back though is a black image (e.g my background image color).
Bryce,
Some things to check:
o Try an absolute path to the png file. Sometimes the
relative paths work in surprising ways.
o Verify the extents of your raster overlap your map.
o Try with LAYER status set to DEFAULT.
But in your case, I think the problem is that you have no world
file for you png file. While the default coordinates will be in the
range 0-125 and 0-125, it will be considered "upside down" by
GDAL and for that reason mapserver might not plot it. Try creating
a world file called testing_29_28.wld that contains six lines:
1
0
0
-1
0.5
124.5
Good luck,
and watch the world go round - Rush | Geospatial Programmer for Rent
