Fwd: [UMN_MAPSERVER-USERS] How to edit attribute of a selected
shape?
Xiaonan Zhang
xnzhang11 at GMAIL.COM
Tue Jan 31 09:25:43 EST 2006
Hi Skalaski,
Thanks for the code. I tried it but it didn't work. There are errors when
change the db file I think. Please see my code used. Also could you please
give me the code of the html input. I have to done this very soon otherwise
I will not ask this.
/* check if it's the comment button which is pressed */
else if ($HTTP_FORM_VARS["CMD"] == "COMMENT")
$oPixelPos = ms_newpointobj(); // to record the click position
if ($HTTP_FORM_VARS["INPUT_TYPE"])
$szCoord = strval($HTTP_FORM_VARS["INPUT_COORD"]);
$szCoordType = strval($HTTP_FORM_VARS["INPUT_TYPE"]);
if (strcmp($szCoordType,"auto_point") == 0)
$szCoordArray =explode(",", $szCoord);
$nClickPixX = $szCoordArray[0];
$nClickPixY = $szCoordArray[1];
} //Get the point screen location
//Covert to geo-location
$nClickGeoX = GMapPix2Geo($nClickPixX, 0, $dfWidthPix,
$dfMinX, $dfMaxX, 0);
$nClickGeoY = GMapPix2Geo($nClickPixY, 0, $dfHeightPix,
$dfMinY, $dfMaxY, 1);
//Create a new comment point
$oClickGeo = ms_newPointObj();
$oClickGeo->setXY($nClickGeoX, $nClickGeoY);
//printf("ClickGeoX %f<BR>\n",$nClickGeoX);
//printf("ClickGeoY %f<BR>\n",$nClickGeoY);
//Add it to the comments layer
$shape = ms_newShapeObj(MS_SHAPE_POINT);
$line = ms_newLineObj();
$line->add($oClickGeo);
$shape ->add($line);
//print_r($shape->values);
//$shape->set ($shape->values["Comment"], "neweddddd"); // change
the comment attributes
//$shape->values["Comment"]= "neweddddd";
$poLayer = $gpoMap->getlayerbyname(comments); //get the layer
"comments"
//$poLayer->open();
//printf("Layer Name: %f<BR>\n", $poLayer->name);
//change the comment attribue here
//$newArr= array(1,1,comment);
//$shape->set(values, $newArr); //error, values is not a property
$poLayer-> addfeature($shape); //add the new comment point
//Task1: input the new comment
//Method1:Input form
Printf( "
<input TYPE='text' NAME=\"new_comment\" value='Please add you
comment here!' size =80>
<input TYPE='submit' value='Add'>");
//end of method1
//Metod 2:pop up a window for user to input comments
//Printf("The new comment is %f<BR>\n",$_GET['new_comment']);
//Save the changes
//$cmmShapefile = "../htdocs/e_Salford/data/comments";
$objShapefile = ms_newShapeFileObj(
'../htdocs/e_Salford/data/comments', -2 );
$dbname= "C:/ms4w/Apache/htdocs/e_Salford/data/comments.dbf";
$db = dbase_open($dbname, 2);
$nf = dbase_numfields($db);
$rn = dbase_numrecords ($db);
$vatr =array("new comment here", 1) ;
if (ereg("([0-9]+)", $HTTP_FORM_VARS["new_comment"], $vatr))
$def = array($vatr[0]);
else
$def = array($rn+1);
$objShapefile->addPoint($oClickGeo);
dbase_add_record($db, $def);
dbase_close ($db);
$objShapefile->free();
$oClickGeo->free();
regards
Jonathan
On 27/01/06, Skalski Artur - askals <Artur.Skalski at acxiom.com> wrote:
> OK this is a part of the php code I used to add point to shp, notice to
> use it you have to first give an attribute value (fill a html input) which
> you will save in a dbf. file, than click on a map to add this point (I was
> using previously created blank shp. file)
> ad here is the code:
> else if ($HTTP_FORM_VARS["CMD"] == "INPUT_POINT")
> $oPoint = ms_newPointObj();
> $oPoint->setXY($nClickGeoX, $nClickGeoY);
> $oshpfile = ms_newShapefileObj('C:\Program Files\Apache
> Group\Apache2\htdocs\data\siedlce\ptk', -2);
> $dbname = "C:/Program Files/Apache
> Group/Apache2/htdocs/data/siedlce/ptk.dbf";
> $db = dbase_open ( $dbname,2);
> if (ereg("([0-9]+)", $HTTP_FORM_VARS["atrybuty"], $vatr))
> $def = array($vatr[1]);
> else
> $oshpfile->addPoint($oPoint);
> dbase_close ($db);
> $oshpfile->free();
> $oPoint->free();
> usig this i never had any problem with overwriting allready added points,
> no such thing happened
> hope this helps
> regards
> Artur Skalski
> *ACXIOM Polska*
> Telephone: (+48 22) 606 11 27 Budynek Saturn
> Facsimile: (+48 22) 606 11 28 Domaniewska 41
> Mobile: (+48) 503 070 036 02-672 Warszawa
> E-mail: artur.skalski at acxiom.com
> -----Original Message-----
> *From:* Xiaonan Zhang [mailto: xnzhang11 at gmail.com]
> *Sent:* Thursday, January 26, 2006 12:59 PM
> *To:* Skalski Artur - askals
> *Cc:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Subject:* Re: [UMN_MAPSERVER-USERS] How to edit attribute of a selected
> shape?
> hi, Skalski,
> Thanks for the reply. However could you please give more information on
> this. Maybe an example.
> The code was working partly ok, the new point can be added, however as I
> said, it will overwrite the old one. It's attribute was inherited from the
> old one. I now want to change it's attribute and when I
> use $poLayer->getResult(0); there seems not point was picked up.
> regards,
> Jonathan
> On 26/01/06, Skalski Artur - askals <Artur.Skalski at acxiom.com > wrote:
> > To change an attribute of added point You have to also update a dbase
> > file (I don't see that in your code) wihich stores all atributes of shapes
> > in shp.file, otherwise you get nothing. And if you try to open such a
> > file in ArcViwe it will promt taht tha file was damaged which is because
> > dbf. file record number doesn't mach shp. file record number.
> > dbase.dll which is used to create and update dbf. file comes with
> > standard distribution off all lates php binaries
> > ragards
> > Artur Skalski
> > *ACXIOM Polska*
> > *From:* UMN MapServer Users List [mailto: MAPSERVER-USERS at LISTS.UMN.EDU]
> > *On Behalf Of *Xiaonan Zhang
> > *Sent:* Wednesday, January 25, 2006 6:02 PM
> > *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> > *Subject:* [UMN_MAPSERVER-USERS] How to edit attribute of a selected
> > shape?
> > Dear all,
> > I am tring to create a function which can add comment point onto layer
> > however I got a few problems here:
> > 1. the newly added one always overwrite the existing point so there is
> > always only one point in that layer.
> > 2. I can not regain the added point.
> > 3. how to change the attribute of the added point, say there is one
> > attribue called "Comment".
> > thanks.
> > My code is:
> > $ClickGeo = ms_newPointObj();
> > $ClickGeo->setXY($nClickGeoX, $nClickGeoY);
> > "comments"
> > $poLayer->open();
> > //Save the changes
> > $cmmShapefile = "../htdocs/data/comments";
> > $objShapefile = ms_newShapeFileObj( $cmmShapefile,
> > MS_SHP_POINT );
> > $objShapefile->addshape($shape);
> > $objShapefile->free;
> > $poLayer->close();
> > //Task2: Use layer->querybypoint to regain the newly added
> > point and then change it's comment attribut
> > //Task2.1:get the new added comment point
> > $poLayer->querybypoint($oClickGeo, MS_SINGLE, 2);
> > $numResults = $poLayer->getNumResults();
> > printf("Find point: %f<BR>\n",
> > $numResults);
> > $oRes = $poLayer->getResult(0);
> > printf("tileindex: %f<BR>\n", $oRes->tileindex);
> > printf("SHAPEINDEX: %f<BR>\n",
> > $oRes->shapeindex);
> > $oShape = $poLayer->getShape(-1,0); //(-1,-1)
> > print_r($oShape->values); //print the keys of the values
> > array
> > $comment = $oShape->Values["Comment"];
> > printf("The comment attribute is ---: %f<BR>\n",$comment
> > ); //display comment attribute
> > The information contained in this communication is confidential, is
> > intended only for the use of the recipient named above, and may be legally
> > privileged.
> > If the reader of this message is not the intended recipient, you are
> > hereby notified that any dissemination, distribution or copying of this
> > communication is strictly prohibited.
> > If you have received this communication in error, please resend this
> > communication to the sender and delete the original message or any copy
> > of it from your computer system.
> > Thank You.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060131/0da29a1d/attachment.html
