How do you get or use fontsets
Trond Michelsen
trondmm-mapserver at CRUSADERS.NO
Sat Jul 1 04:40:10 EDT 2006
On Fri, Jun 30, 2006 at 01:40:25PM -0700, Albert Anderson wrote:
> Where Do I put the tff's at.
Wherever you want.
> In var/www/htdocs/fonts in the fonts?
If you want.
> where my fontset.txt is?
If you use relative paths, they are considered to be relative to the
location of the fontset.
> I put
> arial var/www/htdocs/fonts/arial.ttf
> arial-bd var/www/htdocs/fonts/arialbd.tff
> in the fontset.txt and it still shows up the error message
> msGetLabelSize(): TrueType Font error. Requested font (arialbd) not
> found. I'm I putting something in the wrong place?
Well, there are three things that could be wrong here.
First, you're requesting a font that hasn't been defined. Your
fontset.txt defines "arial" and "arial-bd", while your mapfile
requests "arialbd".
Second, the "arial-bd" definition points to a file ending in .tff,
while I'm pretty sure it's supposed to end in .ttf
Finally, you are using relative paths, and my guess is that this isn't
what you wanted. Try to change the fontlist to this:
arial /var/www/htdocs/fonts/arial.ttf
arial-bd /var/www/htdocs/fonts/arialbd.tff
If you want to test if your paths are correct, here's what you do:
First go to the directory where the fontlist is. If the fontlist is
/var/www/htdocs/fontset.txt , do this:
cd /var/www/htdocs
then check each font from the fontlist with ls, like this:
ls -l var/www/htdocs/fonts/arial.ttf
ls -l var/www/htdocs/fonts/arialbd.tff
If these commands doesn't find any files, your paths are wrong, and
mapserver won't find the fonts either.
Trond Michelsen
