PERL interface trouble
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Mon Jul 3 12:02:10 EDT 2006
You can get at the MapServer error stack with a call like:
my $map = new mapscript::mapObj( $mapfile ) or mapscript::msGetErrorString("\n");
That may help, or be something to try. I use perl MapScript with 4.8 and the CVS version all the time with good results.
Steve
>>> Joseph Bussell <joe at OTSYS.COM> 6/30/2006 2:09:06 PM >>>
Does anyone use the latest code with PERL Mapscript? If shp2img works
with my mapfile, is there anything else I can do to understand why my
new call for the mapObj fails?
Joe Bussell
On Time Systems
Joseph Bussell wrote:
> I have verified that shp2img constructs an image that derives form my
> mapfile. This part looks good. My mapscript code was written for
> 4.4.2, but the one function that is failing does not appear to have
> significantly changed. I am not getting past construction of the
> basic mapObj from the mapfile. Specifically, the call to :
> my $map = new mapscript::mapObj( $mapfile ) or carp "Could not create
> mapscript object from mapfile: $mapfile";
> produces the error message. I also went into mapscript.pm and added
> debug code there to be sure I was using the correct module. The low
> level call is producing an unusable result.
> Joe Bussell
> On Time Systems
> Stephen Woodbridge wrote:
>> Hi Joe,
>> A couple of things.
>> 1) what version does you existing code work on?
>> 2) There are probably two areas that you will need to change
>> a) the mapfile
>> b) the perl
>> I would start with using shp2img to make sure you mapfile can load.
>> It will at least print errors that you can read.
>> shp2img -m /path/to/file.map -o junk.png ...
>> Once you can get an image then you will probably have more luck
>> tracking down the various mapscript changes. These will depend on
>> what version of mapscript your code was written for.
>> -Steve W.
>>> Greetings Listers,
>>> It has been a while since I deployed a new Mapserver application.
>>> I have been leaning on old source on an old box to get the work
>>> done. I have been given a new server to set up for our Air Force
>>> project and have had some issues with getting my code to work.
>>> First of all I am using Mapscript ala PERL. I recognize that the
>>> PERL interface has not been updated due to a lack of user interest,
>>> but I am still partial to using it if it can still be done (mostly
>>> since I will not have to rewrite my routing path functionality).
>>> My problem is getting the actual mapObj to construct from my
>>> mapfile. I have not been able to get any debug information our by
>>> checking /tmp/mserrors, which used to work nicely in such cases.
>>> All I get is an undefined reference. My code for construction is
>>> simple:
>>> create mapscript object from mapfile: $mapfile";
>>> in my httpd.conf I define
>>> MS_ERRORFILE /tmp/mserrors.txt
>>> My mapfile exists and is very simple.
>>> I am running:
>>> CentOS release 4.3
>>> AMD64, dual core machine
>>> Apache/2.0.52
>>> mapserver-4.8.3.tar.gz
>>> perl, v5.8.5 built for x86_64-linux-thread-multi
>>> Thank you for your time.
>>> Joe Bussell
>>> On Time Systems
