I have an HTML legend template file that works wonderfully in MapServer 4.4
and below. However when using MapServer 4.6 and above my legend breaks. I
have thoroughly searched and tested for other possible problems but I have
concluded that the problem must lie somewhere in MapServer. Either
MapServer 4.6 and above reads HTML Legend template files differently than
older versions, or this is a bug in MapServer 4.6 and above. MapServer 4.6
and above handle the legend well when the mapfile contains a few layers.
But when the number of layers gets large (~10-15), the legend file's code is
never even entered. The CGI legend tag in my HTML file is simply skipped.
I have included my template file below. I am fairly desperate so any
thoughts are helpful. I would like to move to MapServer 4.8 but need the
legend to work first. Thanks.
[leg_layer_html order_metadata=orderby opt_flag=15]
[if name=display oper=isset]
<SCRIPT type="text/javascript">
i03++;
sLayerOrClassName[i03] = "&lyr&" +
"[leg_layer_name]";
sDisplayName[i03] = "[metadata
name=display]";
iMinScale[i03] = "[metadata
name=minscl]";
iMaxScale[i03] = "[metadata
name=maxscl]";
</SCRIPT>
[if name=grp oper=isset]
sGrp[i03] = "[metadata
name=grp]";
</SCRIPT>
[/if]
[if name=layer_type oper=neq value=3]
bLayerType3[i03] = false;
</SCRIPT>
[/if]
[if name=layer_type oper=eq value=3]
bLayerType3[i03] = true;
</script>
[/if]
[if name=layer_status oper=eq value=1]
bLayerOn[i03] = true;
</SCRIPT>
[/if]
[if name=href oper=isset]
sHref[i03] = "[metadata
name=href]";
</SCRIPT>
[/if]
[if name=desc oper=isset]
sDesc[i03] = "[metadata
name=desc]";
</SCRIPT>
[/if]
[/if]
[/leg_layer_html]
[leg_class_html opt_flag=15]
i03++;
sLayerOrClassName[i03] = "&cls&" +
"[leg_class_name]";
sImageName[i03] = "[leg_icon width=20
height=10]";
</SCRIPT>
[/if]
[/leg_class_html]
Jason Sievers
Linn County, Oregon
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060703/0c640748/attachment.htm>
