vector over raster not displayed correctly
luca marletta
lucamarle at GMAIL.COM
Mon Jul 3 17:35:04 EDT 2006
Thanks for reply Jukka,
Yes all layers works individually but generally I putted my raster
layer at the end of map file. Because I had the strange idea that ms
start to draw from the bottom.
So now works well
Thanks a lot
luca
On 7/3/06, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
> That should not be any problem. I suppose you have already tested your layers one by one to see that they all work individually, some style is defined etc.? If layers have also been ordered so that the raster layer is drawn first I fear not much could be said without seeing your mapfile and request.
luca marletta
