Change the map size -- C# MapScript
Eduard Witteveen
e.witteveen at HAWARIT.COM
Tue Jul 4 06:36:49 EDT 2006
Zhonghai Wang schreef:
> To get maps with different map size, I am trying to change the SIZE of the
> mapobject like this:
> map.setSize(200,150), where map is a defined mapobject
First of all, i dont know if you are trying this for the first time, or
you if you are trying to upgrade an application. I assume that you are
doing the first.
I use the following code:
> mapObj map = new mapObj(mapfilename);
> map.setImageType(filetype);
> map.setSize(pbMapImage.Width, pbMapImage.Height);
> imageObj image = map.draw();
> image.save(imagefilename, map);
> pbMapImage.ImageLocation = imagefilename;
> but this seems not to work in my application.
> I am using:
> 1. MS4W1.5.3 (directly downloaded from the web site. )
> 2. VS2005
> no ideas what happened with the setSize().
You can look at my test-code at: http://nergens.org/projects/mapviewer/,
the file Mapviewer.NET.2.0_1.1.zip contains a vs2005 project. I've had
some trouble with using the correct version of mapserver
(http://comments.gmane.org/gmane.comp.gis.mapserver.user/16866 )
Maybe this code can get you started (and help you test where things go
wrong)
Ing. Eduard Yeb Witteveen Software Engineer
Hawar Information Technology bv lid Dijkoraad Groep
De Wymerts 7 8701 WT Bolsward
Tel: +31 (0)515 570333 Fax: +31 (0)515 570335
http://www.hawarit.com/ nl_NL fy_NL en_US
