R: [UMN_MAPSERVER-USERS] Oracle10g and queryByAttributes
Fernando Simon
fsimon at UNIVALI.BR
Tue Jul 4 07:28:56 EDT 2006
Hi Antonio,
Yes, the idcolumn must be a numeric type, I just used the nested
select to restrict the number of columns that are used by Mapserver.
I believe that the problem in your case is the numeric column, can
you define a numeric column in UNIQUE definition?
Best regards.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://www.univali.br/g10 - UNIVALI/CTTMAR
Antonio Iandolo wrote:
> Hi all
> Thanks for the answer, Fernando, but I still can't get the solution...
> My DATA are the following:
> DATA "GEOM FROM mytable USING UNIQUE myidcolumn SRID 8307"
> (Note: myidcolumn is a VARCHAR2(16), is it a problem? Should it be
> numeric?)
> Why did you use a nested select in the DATA? Is it an old bug solved in
> 4.8.3 MapServer version?
> I've tried all the following settings, getting always the same result
> (shapeindex < 0):
> DATA "GEOM FROM mytable USING UNIQUE idcolumn SRID 8307 FILTER"
> DATA "GEOM FROM mytable USING UNIQUE SRID 8307 FILTER"
> DATA "GEOM FROM mytable USING UNIQUE SRID 8307 VERSION 10g FILTER"
> The query returns 1 shape (i.e. $layer->getNumResults() = 1), but after
> these statements
> $layer->open();
> $result=$layer->getResult(0);
> I do a simple var_dump($result) and I get:
> result=object(stdClass)(3) { ["shapeindex"]=> int(-2028233538)
> ["tileindex"]=> int(-1) ["classindex"]=> int(0) }
> That is $result->shapeindex < 0!! So the following $shape is "False":
> $shape=$layer->getShape(-1,$result->shapeindex);
> ...I don't think that $result->shapeindex should be negative...
> My software environment is:
> - Windows XP Professional SP1
> - Apache 2.0.55
> - MapServer 4.8.3
> - php 4.4.3-dev (MS4W 1.5.3)
> - php_mapscript_48.dll (232Kb - 09/05/2006 17.22)
> - Oracle10g (XE)
> I have both Oracle8i and Oracle10g installed (server and client), but
> I've renamed the Oracle8i's home directory.
> May I know your MapServer version, Php version and php_mapscript's
> version (maybe also php_mapscript.dll's size and date)?
> Maybe the problem is the php's "dev" version...(I'll "downgrade" to a
> stable version)
> Any further hint?
> Thanks in advance,
> Antonio
>> Hi Antonio,
>> How did you defined your DATA parameter for you layer?
>> The extents for your query are right?
>> Here I use this code as example:
>> // Performing the query and returning only a single record
>> @$qlayer->queryByAttributes($nm_field_query, $regex,
>> MS_SINGLE);
>> $numresults = $qlayer->getNumResults();
>> if ($numresults > 0)
>> for($f = 0; $f < $numresults ; $f++)
>> // Opening the layer to return data
>> $qlayer->open();
>> // Getting the object that store the results
>> $indexResult = $qlayer->getResult($i);
>> $qresult =
>> $qlayer->getShape(-1,$indexResult->shapeindex);
>> // Getting the data from object
>> // The "values" contains the data
>> // for all columns that are in layer
>> data definition
>> // You can get all columns that are
>> in data definition
>> $dataResult = array($qresult->values[STATE]);
>> // Cleaning and closing objects
>> $qresult->free();
>> $qlayer->close();
>> return $dataResult[0];
>> And my DATA definition:
>> data "geo_column from (SELECT geo_id, state, totpop,
>> geo_column FROM tb_states) USING UNIQUE geo_id FILTER"
