nothing shows up! no image or error?
Brock Anderson
banders at REFRACTIONS.NET
Wed Jul 5 13:29:24 EDT 2006
Albert,
For each layer it's important to tell mapserver which projection your
data is stored in. In your case:
LAYER
PROJECTION
"init=epsg:26914"
END #PROJECTION
END #LAYER
The epsg code 26914 represents "NAD83 / UTM zone 14N". I think that's
what you're looking for.
Brock
Albert Anderson wrote:
> Hi,
> I was using a projection file UTM Zone 14n Nad_83. Then I switch to an
> unprojective file and I saw my data show up. What would be the first
> best step for setting a projection file?
> Thanks
> Albert
> */"Fawcett, David" <David.Fawcett at state.mn.us>/* wrote:
> You may want to take a look at your extent.
> Do you really intend to show a primarily empty stretch of the
> northern Atlantic Ocean (apologies to Canary Islanders...)?
> You are telling MapServer that your map area is contained within a
> box from 50 deg. west longitude to 10 deg. west longitude and 20
> to 90 degrees north latitude. If the name of your mapfile relates
> to the data, I am guessing that Richland County isn't in this box.
> Use ogrinfo or a desktop GIS app to look at the extent of your
> data. Also, the extent needs to be in the units of the spatial
> reference system that your data is in.
> David.
> -----Original Message-----
> *From:* UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On Behalf Of *Albert
> Anderson
> *Sent:* Wednesday, July 05, 2006 10:10 AM
> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Subject:* [UMN_MAPSERVER-USERS] nothing shows up! no image or
> error?
> Hi,
> I am making my own map file. It looks all right but when I
> click the button it doesnt show an image or any kind of errors.
> Here is my map code.
> #This is Richland County Map Server
> NAME "Richland"
> SIZE 100 100
> IMAGECOLOR 255 255 255
> IMAGETYPE JPEG
> SHAPEPATH "/home/mapdata/"
> EXTENT -50.00 20.00 -10.00 90.00
> WEB
> TEMPLATE '/var/www/htdocs/richland.html'
> IMAGEPATH '/var/www/htdocs/tmp'
> IMAGEURL '/tmp/'
> END
> LAYER
> NAME "Richland"
> STATUS default
> TYPE polygon
> DATA "RICH_bndy"
> CLASS
> STYLE
> COLOR 0 0 0
> END
> END
> END
> END
> here is my html code
> <html>
> <head><title>Richland County MapServer</title></head>
> <body>
> <form method=post action="/cgi-bin/mapserv">
> <input type="submit" value="Click Me"
> <input type="hidden" name="map"
> value="/home/mapdata/richland.map">
> <input type="hidden" name="map_web_imagepath"
> value="/var/www/htdocs/tmp/">
> </form>
> <table border="1" width="400" height="400">
> <tr>
> <td align="center" valign="top">
> <IMG SRC="[img]" width="400" height="400" border="1">
> </td>
> </tr>
> </table>
> </body>
> </html>
> I really dont know whats could be wrong. Maybe the extent of
> it? Can anyone help me?
> Thanks,
> Albert
> How low will we go? Check out Yahoo! Messenger’s low
> PC-to-Phone call rates.
> <http://us.rd.yahoo.com/mail_us/taglines/postman8/*http://us.rd.yahoo.com/evt=39663/*http://voice.yahoo.com>
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
