CGI vs. WMS
Paul Ramsey
pramsey at REFRACTIONS.NET
Fri Jul 7 15:33:57 EDT 2006
Jim,
David's advice is right on the money... build up a mode=map URL in your
scripting environment (CF, PHP, whatever) and then fire that off to the
mapserver backend. Using WMS mode is actually more restrictive than
just using the Mapserver CGI variable controls
<http://mapserver.gis.umn.edu/docs/reference/cgi/controls> with which
you can actually do many/most of the things people lean on mapscript
for. (Things like dynamically changing aspects of styling or filtering
or even the PostGIS DATA statements (feel the power!)).
We've used mode=map + cgi variable controls to build some pretty
complicated sites (dynamically do thematic mapping of US census data,
for example, changing variables, color themes, categorization, etc on
the fly) without using mapscript.
Paul
Fawcett, David wrote:
> Jim,
> For adding simple mapping to CF apps, I have used CF to dynamically
> build a URL request that I then call with <CFHttpRequest>. I use
> mode=map, so the images don't go to the tmp directory.
> I am guessing that going to a WFS layer for your data source may slow
> down your app.
> David.
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Jim Cser
> Sent: Friday, July 07, 2006 1:15 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] CGI vs. WMS
> What are the pro and cons of using WMS over CGI MapServer? Does anyone
> here have any direct experience with both?
> We have a Cold Fusion web application that displays a few maps, with
> only simple pan/zoom functionality needed * it's not a "GIS-like" site.
> Our previous MapServer apps have used CGI MapServer, but for this app we
> decided to experiment with implementing a WMS service. We're a CF shop,
> otherwise we might try PHP or Java mapscript. Our map layers are coming
> from PostGreSQL/ PostGIS, for what it's worth.
> The WMS was nice because of the detailed diagnostics returned on errors,
> and for the fact that we aren't filling up a directory with
> image files. On the other hand, the lack of ability to dynamically
> control the symbology is becoming a show-stopper, and with CGI we can at
> least throw it a URL containing terms like
> "map_layername_class_expression=('[PROJECT_ID]'='89' ".
> Similarly, will switching to a WFS service, or calling a WFS layer in
> the WMS map file have any advantages? I was looking into filter
> encoding, but was getting lost by the distinction between returning
> features and returning an image.
> At this point in our development cycle, it would be preferable to "drop
> in" some functionality, rather than re-write a lot of code, but as I
> said above, dynamic symbology is the driver.
> Thanks,
> Jim Cser
