Problem drawing image with java/mapscript when starting with
a blank mapObj
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Sat Jul 8 06:11:17 EDT 2006
Please open an issue on mapserver bugzilla.
I'll look into ti asap.
Umberto
On 7/7/06, James Dracup <jamesdracup at hotmail.com> wrote:
> Hello,
> I am using java/mapscript embedded inside a java program and am having a few
> problems. I wonder if anybody has any suggestions, or if it is something
> obvious I have missed?
> I create a new mapObj in java, but NOT from a .map file, a blank one:
> mapObj mapobj = new mapObj(null);
> There is then a fairly long and complicated chunk of code to populate that
> mapObj from a db and user input with settings and layers etc. etc.
> I finally do:
> byte[] bytes = mapobj.draw().getBytes();
> Intending to then further process in java the image returned.
> However, I always get a blank (just background colour) image. Initially I
> thought I'd missed something out when setting the parameters for the various
> mapscript objects, but, having looked at that for a while, I now do not
> think that is the problem.
> If I do a mapobj.save("MapFileName.map") - the .map file outputted is
> perfect, and works fine (displays a map) in all contexts (cgi-bin, java
> mapscript).
> I can load that .map file into a new mapObj, and the image produced is fine:
> mapObj newmapobj = new mapObj("MapFileName.map");
> byte[] bytes = newmapobj.draw().getBytes();
> If I then do a newmapobj.save("MapFileToCompare.map") - the .map file
> outputted is absolutely and completely identical (did a diff) to the
> original one outputted.
> So I am really confused - it seems to me the mapObj's are identical - so why
> do I need to go via the file system in order to produce an image? What
> changes, and how can I avoid it?
> Any thoughts,
> Thanks,
> James
