.DM File Format
Akio Takubo
takubo at SARUGA-TONDARA.NET
Mon Jul 10 07:41:26 EDT 2006
Hi, Thomas and all,
Sorry, I'd sent following mail directly to Thomas but not sent to ML.
Someone may have interests this so I'll sent again to ML.
DM file is GIS format defined by Japanese goverment.
This format is widely used by goverment and local goverment in japan,
maybe only in japan.
It's specification is publshed so you can buy.
(following link is written in japanese).
http://www.sokugikyo.or.jp/book_08.html
Thanks,
Akio Takubo
from Tokyo, Japan
On Mon, 10 Jul 2006 19:57:18 +0900
Thomas Hammerlund <tom at MAPLINK.JP> wrote:
> Thank you very much.
> The data might be in x, y format - I haven't been able to make much sense of
> it yet. Basically it looks like this.
> M 01 #0#1!!!!!!!!!!!!!!!! 25008)C10];}Bh#0#1!]#0#2!]!]#4#09f 0
> -136018 26693-134302 29793 26056 124904 10-134302 26693-136018 29793
> 02
> 0510051000#D#I#A#P!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!100
> 9q:]9R6H3t<02q<R!!!!!!!!!!!!!!!!!!!!!!!! -62 4 -94 4 -94 4 -62 4
> H 1100 0 1 1 0 0 1 0 0 0 0 0 000510
> 0
> E21103 1 2 03 60 00 33 9 0 0 0 0 0510
> 1
> 0 264954 0 2510 265086 0 9467 266997 0 14665
> 265766 0
> 20901 265532 0 32198 263786 0 35178 263861 0 41656
> 265611 0
> 45197 263769 0 49691 262341 0 55551 258232 0 59902
> 254936 0
> 64366 254290 0 73035 253092 0 86465 248904 0 86275
> 255552 0
> 87565 259421 0 89858 262064 0 90721 263492 0 90937
> 265127 0
> 90660 267222 0 90438 271160 0 92763 275983 0 93605
> 284321 0
> 91921 286163 0 85827 291201 0 83668 293688 0 76970
> 297180 0
> 73937 299899 0 72838 301821 0 72574 303743 0 75135
> 306732 0
> 75666 310000 0
> H 2100 0 1 421 0 0 421 0 0 0 0 0 000510
> 0
> E22101 1 2 03 60 01 2 1 0 0 0 0 0510
> 1
> 1938 238580 52985 2082 238843 52985
> E22101 2 2 03 60 01 2 1 0 0 0 0 0510
> 1
> 885 224636 49611 1089 224855 49611
> E22101 3 2 03 60 01 2 1 0 0 0 0 0510
> 1
> 11782 289788 56566 11571 290093 56566
> E22101 4 2 03 60 01 2 1 0 0 0 0 0510
> 1
> 23440 144000 40055 23283 144255 40055
> E22101 5 2 03 60 01 2 1 0 0 0 0 0510
> 1
> 2327 139468 37716 1982 139524 37716
> E22101 6 2 03 60 01 2 1 0 0 0 0 0510
> 1
> 66276 137482 48179 66332 137777 48179
> E22101 7 2 03 60 01 2 1 0 0 0 0 0510
> 1
> 70854 142545 51013 70885 142844 51013
> E22101 8 2 03 60 01 2 1 0 0 0 0 0510
> 1
> 2605 132449 38135 2922 132693 38135
> E22101 9 2 03 60 01 2 1 0 0 0 0 0510
> 1
> 4616 169882 41840 4363 170142 41840
> E22101 10 2 03 60 01 6 2 0 0 0 0 0510
> 1
> 17817 117965 37238 17092 118039 37287 16305 118153 37335 15634
> 118288 37367
> ----- Original Message -----
> From: "Bart van den Eijnden (OSGIS)" <bartvde at xs4all.nl>
> To: "Thomas Hammerlund" <tom at MAPLINK.JP>
> Cc: <mapserver-users at lists.umn.edu>
> Sent: Monday, July 10, 2006 7:53 PM
> Subject: Re: [UMN_MAPSERVER-USERS] .DM File Format
> > Is this a table with X and Y values?
> > If so, once you have it in Access you can set up OGR Virtual Spatial Data
> > (an ovf file) for your Access table. See also:
> > http://iweb.gdal.org/ogr/drv_vrt.html
> > Ogr can output shapefiles so using the ogr2ogr utility you can transform
> > the data to a point shp.
> > Bart
> >> Thank you Stephen.
> >> This is probably out of the scope of the list, but do you know if there
> >> is
> >> there a way to convert them to Shape files?
> >> Thank you again.
> >> Tom
> >> From: Stephen Kelly
> >> To: 'Thomas Hammerlund' ; MAPSERVER-USERS at LISTS.UMN.EDU
> >> Sent: Monday, July 10, 2006 7:43 PM
> >> Subject: RE: [UMN_MAPSERVER-USERS] .DM File Format
> >> Tom,
> >> MS Access can import Paradox (.db) files
> >> Stephen Kelly
> >> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> >> On
> >> Behalf Of Thomas Hammerlund
> >> Sent: Monday, 10 July 2006 6:15 PM
> >> To: MAPSERVER-USERS at LISTS.UMN.EDU
> >> Subject: [UMN_MAPSERVER-USERS] .DM File Format
> >> Hi Everyone,
> >> I have some data in .dm format. I have never seen this beofre but
> >> here's
> >> what I've found:
> >> It's a format from a company called Borland Software, and there's some
> >> kind of database viewercalled Paradox to view the data.
> >> Has anyone seen this file format before, or does anyone know where/how
> >> I
> >> can download the db viewer? It's a file called "pdxwin32.exe", but
> >> Google
> >> isn't being kind today.
> >> Thank you,
> >> Tom
たくぼ あきお(Takubo Akio)
takubo at saruga-tondara.net
さるがとんだら http://www.saruga-tondara.net/
http://co2.s16.xrea.com/hiki2/
