Problem drawing image with java/mapscript when starting with
a blank mapObj
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Tue Jul 11 02:18:22 EDT 2006
On 7/10/06, James Dracup <jamesdracup at hotmail.com> wrote:
> No need for a bug, I had a play over the weekend and found my error.
All's well what ends well!
> I am populating my mapObj from tables in a db. If the value is not null in
> the db, I call the corresponding set method in mapscript. In my 'style'
> table I have 'size' column which was set to have a default value of 0, and
> was never null. I therefore always called styleObj.setSize() - usually
> passing 0. That I think is what was messing me up - changing the default to
> null for that column fixed the issue.
> The reason it worked when passed through a .map file, and the reason I did
> not initially spot the mistake, was because SIZE is not set in the STYLE
> section on any of the map files - so it looked as if the mapObjs were the
> same, but in fact reloading it caused the size value to be forgotten.
> Umberto, thanks for the prompt response in any case and - at a guess from
> your name - congratulations on the World Cup :)
Thanks! We're very proud of our team even in the light of recent scandals...
Umberto
> Cheers,
> James.
> ----Original Message Follows----
> From: "Umberto Nicoletti" <umberto.nicoletti at gmail.com>
> To: "James Dracup" <jamesdracup at hotmail.com>
> CC: MAPSERVER-USERS at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-USERS] Problem drawing image with java/mapscript
> when starting with a blank mapObj
> Date: Sat, 8 Jul 2006 12:11:17 +0200
> Please open an issue on mapserver bugzilla.
> I'll look into ti asap.
> Umberto
> On 7/7/06, James Dracup <jamesdracup at hotmail.com> wrote:
> >Hello,
> >I am using java/mapscript embedded inside a java program and am having a
> >few
> >problems. I wonder if anybody has any suggestions, or if it is something
> >obvious I have missed?
> >I create a new mapObj in java, but NOT from a .map file, a blank one:
> >mapObj mapobj = new mapObj(null);
> >There is then a fairly long and complicated chunk of code to populate that
> >mapObj from a db and user input with settings and layers etc. etc.
> >I finally do:
> >byte[] bytes = mapobj.draw().getBytes();
> >Intending to then further process in java the image returned.
> >However, I always get a blank (just background colour) image. Initially I
> >thought I'd missed something out when setting the parameters for the
> >various
> >mapscript objects, but, having looked at that for a while, I now do not
> >think that is the problem.
> >If I do a mapobj.save("MapFileName.map") - the .map file outputted is
> >perfect, and works fine (displays a map) in all contexts (cgi-bin, java
> >mapscript).
> >I can load that .map file into a new mapObj, and the image produced is
> >fine:
> >mapObj newmapobj = new mapObj("MapFileName.map");
> >byte[] bytes = newmapobj.draw().getBytes();
> >If I then do a newmapobj.save("MapFileToCompare.map") - the .map file
> >outputted is absolutely and completely identical (did a diff) to the
> >original one outputted.
> >So I am really confused - it seems to me the mapObj's are identical - so
> >why
> >do I need to go via the file system in order to produce an image? What
> >changes, and how can I avoid it?
> >Any thoughts,
> >Thanks,
> >James
