trouble in tileindex technique
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Tue Jul 11 14:58:41 EDT 2006
TILEITEM is the name of the field in your index F636_PRG-IDX.dbf file
containing the paths. It is "location" by default. Whatever yours is
should be specified in your TILEITEM parameter of your layer.
jeff
Giuseppe De Rossi wrote:
> Hi,
> I'm performing for the first time the tile index technique in Win xp
> Environment.
> I've generated the *.qix file and I've used tile4ms to generate
> F636_PRG-IDX.(dbf,shx,idx), I've modified the .map file in the following way
> LAYER
> NAME "F636_PRG-IDX"
> STATUS ON
> TILEINDEX "F636_PRG-IDX.shp"
> TILEITEM "F636_PRG-IDX"
> TYPE POLYGON
> END
> But I get this error:
> Class : SoapFaultWrapperMessage : Mapserver error: Error in msDrawMap():
> Failed to draw layer named 'F636_PRG-IDX'.
> Error in msDBFGetItemIndex(): Item 'F636_PRG-IDX' not found.
> am I supposed to perform other action ?
> Thanks in advance and best regards.
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
