ka-map: pgsql layers not rendering tiles [solved]
Dylan Beaudette
dylan.beaudette at GMAIL.COM
Tue Jul 11 18:38:20 EDT 2006
Looks like my php_mapscript.so library was from a previous compile, before
PostGreSQL was included!
Whoops!
Dylan
On Tuesday 11 July 2006 12:45, Dylan Beaudette wrote:
> Greetings,
> Having a blast using ka-map and mapserver, but ran into a bit of trouble
> when including a layer from a postgis source.
> here is the layer defs from my map file, which work fine in a dbox-style
> mapserver application:
> LAYER
> NAME "county-boundaries"
> TYPE POLYGON
> PROJECTION
> "+proj=aea +x_0=0.0 +y_0=0 +lon_0=-96 +lat_0=40.0 +lat_1=20 +lat_2=60.0
> +datum=NAD83"
> END
> DATA "gen_2 from poly_county using unique county_id"
> CONNECTION "user=xxx password=xxx dbname=tiger2005se host=localhost
> port=5432"
> CONNECTIONTYPE postgis
> STATUS DEFAULT
> TRANSPARENCY ALPHA
> STATUS DEFAULT
> MINSCALE 24000
> LABELMAXSCALE 2037392
> LABELITEM "county_name"
> CLASS
> NAME "County Boundaries"
> STYLE
> ANTIALIAS TRUE
> WIDTH 2
> OUTLINECOLOR 1 1 1
> END
> LABEL
> TYPE TRUETYPE
> FONT sans
> SIZE 13
> ANTIALIAS TRUE
> COLOR 20 20 220
> OUTLINECOLOR 255 255 255
> POSITION CC
> PARTIALS FALSE
> BUFFER 2
> END
> END
> END
> I read here
> (http://lists.maptools.org/pipermail/ka-map-users/2005-December/000721.html
>) that ka-map will only work with postgis data if the projection string in
> the layer defs matched the SRID of the geometry itself.
> noticing that my geometry columns had an incorrect SRID, i changed this
> with the postgis function setsrid() ... however when this layer is enabled,
> ka-map will not generate tiles. also, tile.php returns the following error:
> Call to a member function on a non-object in /data1/website/kamap/tile.php
> on line 225
> this appears to be where ka-map is either creating or saving the image:
> $szMetaImg =
> $szMetaDir."/t".$metaTop."l".$metaLeft.$szImageExtension; $oImg =
> $oMap->draw();
> $oImg->saveImage($szMetaImg);
> $oImg->free();
> .... i have a fully functional ka-map application using this same set of
> temp directories, and config files.
> does anyone have any ideas on this?
> thanks in advance!
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
