Mapserver returns blank pages
Stuart Eve
stuarteve at LPARCHAEOLOGY.COM
Thu Jul 13 05:38:05 EDT 2006
After checking the apache error log we also get:
[Thu Jul 13 10:22:02 2006] [notice] child pid 9429 exit signal
Segmentation fault (11)
We are using mapserver 4.8.3, php 4.3.10 and apache 2.0.53 running on a
Suse 10 box.
The mapscript functions that seem to be in use when the crash is caused
are: queryByAttributes(), getResult() and getShape()
should we list this as a bug on Bugzilla?
Thanks
Stuart
Stuart Eve wrote:
> We are having (and have had for while_ this problem - and it does seem
> reasonably random.
> The main trouble is that I don't know how to get php to spew out the
> error - and instead it just returns this blank screen, instead of
> returning the error as it does normally. I had first thought that it
> was because I was using php mapscript and had nested functions - but
> it seems like lots of people are coming up with the same thing.
> Anyone got any ideas?
> Matthew Kane wrote:
>> I wasn't actually using php mapscript in the mapfile that gave me
>> segmentation faults. Strangely, I got the map to display on a Sun
>> machine if I removed all references to true-type fonts and relied
>> only on bitmap fonts for my labels. Even more strange is that when I
>> moved the same file to a red hat server, mapserver simply hangs. No
>> error message in either the browser or the apache error logs, just
>> hanging. The same thing happened when I tried running the mapfile
>> with shp2img. Has anyone else experienced this problem? Could this be
>> a bug in one of the third party libraries that mapserver relies on?
>> Or more likely a problem in how we code our mapfiles?
>> Thanks,
>> Matt
>> On 7/12/06, *antti siukola* <siukola.antti at gmail.com
>> <mailto:siukola.antti at gmail.com>> wrote:
>> Hi!
>> As we can see a lot of people are suffering from this but no one
>> seems
>> to have any solutions. Does this only appear with php mapscript? Is
>> this a bug? A known bug? Is there a solutions? This is a fatal error
>> since this kind of behavior avoids us to use php mapscript in
>> production, in case this is a php mapscript issue as it seems to be.
>> Regards,
>> Antti S
>> On 6/13/06, Matthew Kane < markane at indiana.edu
>> <mailto:markane at indiana.edu>> wrote:
>> > I second that question, as I am receiving Segmentation Faults
>> as well...
>> > Matt
>> > On 6/13/06, antti siukola < siukola.antti at gmail.com
>> > > Hi!
>> > > Every time MapServer returns a blank page I find "[notice]
>> child pid
>> > > xxxx exit signal Segmentation fault (11)" from apache's
>> error_log. Any
>> > > thoughts? Blank pages are returned randomly.
>> > > AnttiS
> Stuart Eve
> L - P : Archaeology
> stuarteve at lparchaeology.com
Stuart Eve
L - P : Archaeology
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060713/9d1cebf2/attachment.html
