Map Projections
Ryan Ollerenshaw
ollerery at ENGR.ORST.EDU
Thu Jul 13 12:34:48 EDT 2006
I am having a bit of trouble re-projecting my data. When I specify the
PROJECTION object in my map file as
PROJECTION
"proj=cc"
"lon_0=0"
"ellps=WGS84"
"datum=WGS84"
END
Or
PROJECTION
"proj=cc"
"lon_0=90"
"ellps=WGS84"
"datum=WGS84"
END
My image does not change, but the prime meridian should be changing locations
from the center of the image to the far left. I also tried to specify the
projection in the layer itself but still no change. Isnt MapServer capable of
re-projecting the data regardless of the original projection?
