500 Internal Server Errors
Roland Martin
roland.w.martin at GMAIL.COM
Fri Jul 14 11:53:17 EDT 2006
Hi Ludwig,
Thanks for your thoughts. I've spent today clutching at straws and testing
every possibility I can think of (including using shapefiles, which turned
out to throw the same error).
Anyway, I *think* (and I really hope I'm not speaking prematurely) that I've
solved this by changing the group names from 'CAD Drawings' to simply
'CAD'...
The bizarre thing is that I can't replicate the error in any of my other
apps.
Anyone have any ideas on why this might be?
Cheers,
Roland.
On 14/07/06, Ludwig Max Brinckmann <ludwigbrinckmann at gmail.com> wrote:
> > > > > > The error is being thrown on loading the map; approximately
> > > > > > 80-90% of the time.
> > > > > > Also of interest may be the following gunk from the error logs:
> > > > > > [Wed Jul 12 16:29:11 2006] [error] [client x] Premature end of
> > > > > > script headers: php-cgi.exe, referer: http://x/lbia_dev/
> > > > > > [Wed Jul 12 16:51:08 2006] [error] [client x] Premature end of
> > > > > > (etc)
> The error you are seeing might have to do more with apache and the long
> delay when getting data.
> This might be the doc you should be looking at:
> http://httpd.apache.org/docs/1.3/misc/FAQ-F.html#premature-script-headers
> HTH
> Ludwig
Please note my new email address. Use other addresses at your peril.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060714/e1acf85a/attachment.html
