How do you use proj-4.4.9
Ryan Ollerenshaw
ollerery at ENGR.ORST.EDU
Fri Jul 14 15:36:08 EDT 2006
Quoting Albert Anderson <bart_doggers at yahoo.com>:
> Hi,
> I dont know why its not working. The projection map file is not showing up
> in the window.
> Albert
We would still need some more information to exacly what problem you are facing.
if all you are getting is a blank display i would bet that you problem is not
with proj4 but somewhere else in you mapserver setup. I think that your best
bet would be to use your MapServer's built in WMS server and try to view your
map through a URL. This would eliminate any coding mistakes that you might
have made else where.
check out: http://mapserver.gis.umn.edu/docs/howto/wms_server
> Ryan Ollerenshaw <ollerery at engr.orst.edu> wrote: How is it not working?
> Quoting Albert Anderson :
> > Hi All,
> > I installed proj-4.4.9 on a lunix machine. I follow the directions step
> by
> > step. It does seem to be work. What should I do. I have the projection in
> > the layer and map. code is here.
> > #This is Richland County Map Server
> > NAME "Richland"
> > SIZE 309 417
> > UNITS DD
> > IMAGECOLOR 189 202 222
> > IMAGETYPE JPEG
> > PROJECTION "init=epsg:26914"
> > END
> > SHAPEPATH "/home/mapdata/"
> > EXTENT -97.338391 45.907505 -96.508389 46.717217
> > and
> > LAYER
> > NAME "richland"
> > STATUS default
> > TYPE polygon
> > DATA "RICH_bndy"
> > END
> > CLASS
> > STYLE
> > COLOR 0 0 0
> > END
> > END
> > END
> > Can someone help me.
> > Thanks,
> > Albert
> > Do you Yahoo!?
> > Everyone is raving about the all-new Yahoo! Mail Beta.
> Do you Yahoo!?
