cant get my lavyers working w/my projection file
Albert Anderson
bart_doggers at YAHOO.COM
Mon Jul 17 11:11:50 EDT 2006
I add a projection map file of richland county. The other layers that I have are unprojective files. The roads file is all the road in the county. Right now they are not catagorized. Thats the way the other layers are. I just want to get the projection file loaded which is and also my layers which are not.
Setting it to default didnt seem to work.
Thanks,
Albert
"Pagurek,Debbie [NCR]" <Debbie.Pagurek at EC.GC.CA> wrote: perhaps you could provide a bit more information to us. What is the native projection of the roads, boundary line, and etc... layers? If it isn't in the same projection as specified in your MAP object,
PROJECTION
"init=epsg:26914"
END
then you also need to specify the projection in the layer object.
you also might want to try to put STATUS DEFAULT for the roads, boundary etc and that way they will ALWAYS be ON. If status is set to ON you have to make sure that your URL specifies layers=layername in order for it to be on.
Hope this helps,
D. Pagurek
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Albert Anderson
Sent: Friday, July 14, 2006 4:58 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] cant get my lavyers working w/my projection file
I got my projection file working but I cant see to get my layers working like roads, boundary line, and etc... Can someone look at my code and help me. Thanks!
---Codes-------
<body>
<form method=POST action="/cgi-bin/mapserv">
<input type="submit" value="Click to initialize">
<input type="hidden" name="program" value="mapserv">
<input type="hidden" name="map" value="/home/mapdata/richland.map">
<input type="hidden" name="mapext" value="626173.309834 5085113.091715 694065.960556 5176735.212592">
<input type="hidden" name="zoomsize" size="2" value="2">
<input type="hidden" name="layers" value="boundary roads sections">
</form>
</body>
</html>
<input type="checkbox" name="layer" value="boundary" [boundary_check]/>
County Boundary <br />
<input type="checkbox" name="city" value="city" />
City Boundary <br />
<input type="checkbox" name="township" value="township" />
Township<br />
<input type="checkbox" name="layer" value="sections" [sections_check]/>
Section Lines </span><br />
<br />
<font color="green"><span class="style2"> Land</span></font><br />
<span class="style4">
<input type="checkbox" name="layer" value="parcels" [parcels_check]/>
Parcels <br />
<input type="checkbox" name="parcelslables" value="parcelslables" />
Parcels Labels</span><br />
<br />
<font color="red"<span class="style2"> Transportation</span></font><br />
<input type="checkbox" name="layer" value="roads" [roads_check]/>
County/City Roads <br />
<input type="checkbox" name="addresslabels" value="addresslabels" />
Address Labels</span> </p>
<p class="style1"><font color="brown"><span class="style2"> Backgrounds</span></font><br />
<input name="aerial" type="checkbox" id="aerial" value="aerial" />
Aerial Photos</span></p>
#This is Richland County Map Server
NAME "Richland"
SIZE 309 417
UNITS miles
IMAGECOLOR 255 255 255
IMAGETYPE JPEG
PROJECTION "init=epsg:26914"
END
SHAPEPATH "/home/mapdata/"
EXTENT 626173.309834 5085113.091715 694065.960556 5176735.212592
# Symbol for drawing fat lines
SYMBOL
NAME "BigLine"
TYPE ELLIPSE
POINTS 1 1 END
END
# Symbol for drawing dashed lines
SYMBOL
NAME "DashedLine"
TYPE ELLIPSE
POINTS 1 1 END
STYLE 10 10 END
END
# Symbol for drawing spots
SYMBOL
NAME "Circle"
FILLED true
TYPE ellipse
POINTS 1 1 END
END
# Web object
WEB
TEMPLATE '/var/www/htdocs/gismapserver_test_project_mod.html'
IMAGEPATH '/var/www/htdocs/tmp/'
IMAGEURL '/tmp/'
END
# Reference map
REFERENCE
IMAGE "/home/mapdata/richland.gif"
SIZE 136 152
EXTENT -97.228391 45.907505 -96.628389 46.717217
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 0 0 0
END
# Scalebar
SCALEBAR
LABEL
COLOR 0 0 0
ANTIALIAS true
SIZE small
END
POSITION lr
INTERVALS 5
STATUS embed
SIZE 144 5
STYLE 0
UNITS MILES
BACKGROUNDCOLOR 0 255 0
COLOR 128 128 128
OUTLINECOLOR 0 0 255
TRANSPARENT off
END
LAYER
NAME "richland"
STATUS default
TYPE polygon
DATA "RICH_bndy"
END
CLASS
STYLE
COLOR 238 220 130
END
END
END
LAYER
NAME "boundary"
STATUS on
TYPE line
DATA "RC_boundary_05"
CLASS
STYLE
COLOR 0 0 0
END
END
END
LAYER
NAME "roads"
STATUS on
TYPE line
DATA "roads_shp"
CLASS
STYLE
COLOR 255 0 0
END
END
END
LAYER
NAME "sections"
STATUS on
TYPE line
DATA "RC_sections_05"
CLASS
STYLE
COLOR 255 130 171
END
END
END
LAYER
NAME "parecles"
STATUS on
TYPE line
DATA "RC_parcels_05"
CLASS
STYLE
COLOR 0 0 0
END
END
END
END
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
See the all-new, redesigned Yahoo.com. Check it out.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060717/47e5a1ee/attachment.html
