cant get my lavyers working w/my projection file
Pagurek,Debbie [NCR]
Debbie.Pagurek at EC.GC.CA
Mon Jul 17 12:33:43 EDT 2006
you have a typo in what you just wrote - it should be epsG not epsQ - I
hope you have epsG in your mapfile.
The error that you're getting indicates that Mapserver can't find the
epsg file so it can't find the epsg code.
On windows in a typical ms4w installation, your epsg file should be in
c:\ms4w\proj\nad\
D. Pagurek
_____
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Albert Anderson
Sent: Monday, July 17, 2006 11:45 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] cant get my lavyers working w/my
projection file
I changed my units and my scale bar looks better. I still cant get my
layers working. I put them on default and put
PROJECTION "init=epsq:4326"
END
in the map object and it didnt like that. I get an error like
msProcessProjection(): Projection library error. no system list, errno:
2 . What else can I try?
Thanks,
Albert
"Pagurek,Debbie [NCR]" <Debbie.Pagurek at EC.GC.CA> wrote:
If your other layers are not projected, you mean that they are
in 'geographic'. You still need to set a projection object for them.
Try
PROJECTION
"init=epsg:4326"
END
This is geographic with the datum set as WGS84. This might not
be the proper settings for your data - you could have another datum...
anyway - set this projection object in your mapfile to see if you can
get it working. What will happen is that Mapserver will project these
layers on the fly to match the projection in your MAP object.
D. Pagurek
_____
From: Albert Anderson [mailto:bart_doggers at yahoo.com]
Sent: Monday, July 17, 2006 11:12 AM
To: Pagurek,Debbie [NCR]; MAPSERVER-USERS at LISTS.UMN.EDU
I add a projection map file of richland county. The other
layers that I have are unprojective files. The roads file is all the
road in the county. Right now they are not catagorized. Thats the way
the other layers are. I just want to get the projection file loaded
which is and also my layers which are not.
Setting it to default didnt seem to work.
Thanks,
Albert
perhaps you could provide a bit more information to us.
What is the native projection of the roads, boundary line, and etc...
layers? If it isn't in the same projection as specified in your MAP
object,
PROJECTION
"init=epsg:26914"
END
then you also need to specify the projection in the
layer object.
you also might want to try to put STATUS DEFAULT for the
roads, boundary etc and that way they will ALWAYS be ON. If status is
set to ON you have to make sure that your URL specifies layers=layername
in order for it to be on.
Hope this helps,
D. Pagurek
_____
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Albert Anderson
Sent: Friday, July 14, 2006 4:58 PM
Subject: [UMN_MAPSERVER-USERS] cant get my lavyers
I got my projection file working but I cant see to get
my layers working like roads, boundary line, and etc... Can someone
look at my code and help me. Thanks!
---Codes-------
<body>
<form method=POST action="/cgi-bin/mapserv">
<input type="submit" value="Click to initialize">
<input type="hidden" name="program" value="mapserv">
<input type="hidden" name="map"
value="/home/mapdata/richland.map">
<input type="hidden" name="mapext"
value="626173.309834 5085113.091715 694065.960556 5176735.212592">
<input type="hidden" name="zoomsize" size="2"
value="2">
<input type="hidden" name="layers" value="boundary
roads sections">
</form>
</body>
</html>
<input type="checkbox" name="layer" value="boundary"
[boundary_check]/>
County Boundary <br />
<input type="checkbox" name="city" value="city" />
City Boundary <br />
<input type="checkbox" name="township"
value="township" />
Township<br />
<input type="checkbox" name="layer" value="sections"
[sections_check]/>
Section Lines </span><br />
<br />
<font color="green"><span
class="style2"> Land</span></font><br />
<span class="style4">
<input type="checkbox" name="layer" value="parcels"
[parcels_check]/>
Parcels <br />
<input type="checkbox" name="parcelslables"
value="parcelslables" />
Parcels Labels</span><br />
<br />
<font color="red"<span
class="style2"> Transportation</span></font><br />
<input type="checkbox" name="layer" value="roads"
[roads_check]/>
County/City Roads <br />
<input type="checkbox" name="addresslabels"
value="addresslabels" />
Address Labels</span> </p>
<p class="style1"><font color="brown"><span
class="style2"> Backgrounds</span></font><br />
<input name="aerial" type="checkbox" id="aerial"
value="aerial" />
Aerial Photos</span></p>
#This is Richland County Map Server
NAME "Richland"
SIZE 309 417
UNITS miles
IMAGECOLOR 255 255 255
IMAGETYPE JPEG
PROJECTION "init=epsg:26914"
END
SHAPEPATH "/home/mapdata/"
EXTENT 626173.309834 5085113.091715 694065.960556
5176735.212592
# Symbol for drawing fat lines
SYMBOL
NAME "BigLine"
TYPE ELLIPSE
POINTS 1 1 END
END
# Symbol for drawing dashed lines
SYMBOL
NAME "DashedLine"
TYPE ELLIPSE
POINTS 1 1 END
STYLE 10 10 END
END
# Symbol for drawing spots
SYMBOL
NAME "Circle"
FILLED true
TYPE ellipse
POINTS 1 1 END
END
# Web object
WEB
TEMPLATE
'/var/www/htdocs/gismapserver_test_project_mod.html'
IMAGEPATH '/var/www/htdocs/tmp/'
IMAGEURL '/tmp/'
END
# Reference map
REFERENCE
IMAGE "/home/mapdata/richland.gif"
SIZE 136 152
EXTENT -97.228391 45.907505 -96.628389 46.717217
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 0 0 0
END
# Scalebar
SCALEBAR
LABEL
COLOR 0 0 0
ANTIALIAS true
SIZE small
END
POSITION lr
INTERVALS 5
STATUS embed
SIZE 144 5
STYLE 0
UNITS MILES
BACKGROUNDCOLOR 0 255 0
COLOR 128 128 128
OUTLINECOLOR 0 0 255
TRANSPARENT off
END
LAYER
NAME "richland"
STATUS default
TYPE polygon
DATA "RICH_bndy"
END
CLASS
STYLE
COLOR 238 220 130
END
END
END
LAYER
NAME "boundary"
STATUS on
TYPE line
DATA "RC_boundary_05"
CLASS
STYLE
COLOR 0 0 0
END
END
END
LAYER
NAME "roads"
STATUS on
TYPE line
DATA "roads_shp"
CLASS
STYLE
COLOR 255 0 0
END
END
END
LAYER
NAME "sections"
STATUS on
TYPE line
DATA "RC_sections_05"
CLASS
STYLE
COLOR 255 130 171
END
END
END
LAYER
NAME "parecles"
STATUS on
TYPE line
DATA "RC_parcels_05"
CLASS
STYLE
COLOR 0 0 0
END
END
END
END
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection
around
http://mail.yahoo.com
_____
See the all-new, redesigned Yahoo.com. Check it out.
<http://us.rd.yahoo.com/evt=40762/*http://www.yahoo.com/preview>
_____
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060717/cc53ad2b/attachment.html
