projection questions????
Albert Anderson
bart_doggers at YAHOO.COM
Mon Jul 17 16:15:58 EDT 2006
Can you put a projection file in a map. Then put regular shp files the layers? How can you do that? I am using mapserver 4 on a lunix machine. I put a projection file in my map file but I only have one of them. The rest are regular shp files. I cant seem to get the layers show up with my projection file.
Thanks,
Albert
#This is Richland County Map Server
NAME "Richland"
SIZE 309 417
UNITS meters
IMAGECOLOR 255 255 255
IMAGETYPE JPEG
#PROJECTION
#"init=epsg:26914"
#END
SHAPEPATH "/home/mapdata/"
EXTENT 626173.309834 5085113.091715 694065.960556 5176735.212592
#EXTENT -97.228391 45.907505 -96.628389 46.717217
# Symbol for drawing fat lines
SYMBOL
NAME "BigLine"
TYPE ELLIPSE
POINTS 1 1 END
END
# Symbol for drawing dashed lines
SYMBOL
NAME "DashedLine"
TYPE ELLIPSE
POINTS 1 1 END
STYLE 10 10 END
END
# Symbol for drawing spots
SYMBOL
NAME "Circle"
FILLED true
TYPE ellipse
POINTS 1 1 END
END
# Web object
WEB
TEMPLATE '/var/www/htdocs/gismapserver_test_project_mod.html'
IMAGEPATH '/var/www/htdocs/tmp/'
IMAGEURL '/tmp/'
END
# Reference map
REFERENCE
IMAGE "/home/mapdata/richland.gif"
SIZE 136 152
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 0 0 0
END
# Scalebar
SCALEBAR
LABEL
COLOR 0 0 0
ANTIALIAS true
SIZE small
END
POSITION lr
INTERVALS 5
STATUS off
SIZE 144 5
STYLE 0
UNITS miles
BACKGROUNDCOLOR 0 255 0
COLOR 128 128 128
OUTLINECOLOR 0 0 255
TRANSPARENT off
END
LAYER
NAME "richland"
STATUS default
TYPE polygon
DATA "RICH_bndy"
PROJECTION "init=epsg:26914"
END
CLASS
STYLE
COLOR 238 220 130
END
END
END
LAYER
NAME "boundary"
STATUS default
TYPE line
DATA "RC_boundary_05"
CLASS
STYLE
COLOR 0 0 0
END
END
END
LAYER
NAME "roads"
STATUS default
TYPE line
DATA "roads_shp"
PROJECTION "init=epsg:4326"
END
CLASS
STYLE
COLOR 255 0 0
END
END
END
LAYER
NAME "sections"
STATUS default
TYPE line
DATA "RC_sections_05"
CLASS
STYLE
COLOR 255 130 171
END
END
END
LAYER
NAME "parecles"
STATUS default
TYPE line
DATA "RC_parcels_05"
CLASS
STYLE
COLOR 0 0 0
END
END
END
END
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1¢/min.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060717/aa816dbc/attachment.html
