projection questions
Albert Anderson
bart_doggers at YAHOO.COM
Mon Jul 17 17:55:20 EDT 2006
I got it working after I sent the email.
Thanks,
Albert
"Fawcett, David" <David.Fawcett at state.mn.us> wrote:Message Albert,
I am pretty sure that this has been pointed out before. MapServer does not use the ESRI .prj files.
You simply need to define projection blocks in your mapfile for both your output projection and for the input projection of each data layer. To do this of course, you will need to know what projection your data is in.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Albert Anderson
Sent: Monday, July 17, 2006 3:18 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] projection questions
Can you put a projection file in a map. Then put regular shp files the layers? How can you do that? I am using mapserver 4 on a lunix machine. I put a projection file in my map file but I only have one of them. The rest are regular shp files. I cant seem to get the layers show up with my projection file.
Thanks,
Albert
#This is Richland County Map Server
NAME "Richland"
SIZE 309 417
UNITS meters
IMAGECOLOR 255 255 255
IMAGETYPE JPEG
PROJECTION
"init=epsg:26914"
END
SHAPEPATH "/home/mapdata/"
EXTENT 626173.309834 5085113.091715 694065.960556 5176735.212592
#EXTENT -97.228391 45.907505 -96.628389 46.717217
# Symbol for drawing fat lines
SYMBOL
NAME "BigLine"
TYPE ELLIPSE
POINTS 1 1 END
END
# Symbol for drawing dashed lines
SYMBOL
NAME "DashedLine"
TYPE ELLIPSE
POINTS 1 1 END
STYLE 10 10 END
END
# Symbol for drawing spots
SYMBOL
NAME "Circle"
FILLED true
TYPE ellipse
POINTS 1 1 END
END
# Web object
WEB
TEMPLATE '/var/www/htdocs/gismapserver_test_project_mod.html'
IMAGEPATH '/var/www/htdocs/tmp/'
IMAGEURL '/tmp/'
END
# Reference map
REFERENCE
IMAGE "/home/mapdata/richland.gif"
SIZE 136 152
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 0 0 0
END
# Scalebar
SCALEBAR
LABEL
COLOR 0 0 0
ANTIALIAS true
SIZE small
END
POSITION lr
INTERVALS 5
STATUS off
SIZE 144 5
STYLE 0
UNITS miles
BACKGROUNDCOLOR 0 255 0
COLOR 128 128 128
OUTLINECOLOR 0 0 255
TRANSPARENT off
END
LAYER
NAME "richland"
STATUS default
TYPE polygon
DATA "RICH_bndy"
PROJECTION "init=epsg:26914"
END
CLASS
STYLE
COLOR 238 220 130
END
END
END
LAYER
NAME "boundary"
STATUS default
TYPE line
DATA "RC_boundary_05"
CLASS
STYLE
COLOR 0 0 0
END
END
END
LAYER
NAME "roads"
STATUS default
TYPE line
DATA "roads_shp"
PROJECTION "init=epsg:4326"
END
CLASS
STYLE
COLOR 255 0 0
END
END
END
LAYER
NAME "sections"
STATUS default
TYPE line
DATA "RC_sections_05"
CLASS
STYLE
COLOR 255 130 171
END
END
END
LAYER
NAME "parecles"
STATUS default
TYPE line
DATA "RC_parcels_05"
CLASS
STYLE
COLOR 0 0 0
END
END
END
END
See the all-new, redesigned Yahoo.com. Check it out.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060717/65491bf2/attachment.html
